Old 03-13-2003, 01:43 AM
starion_999's Avatar
starion_999 starion_999 is offline
Gecko! not Geico...
Just bought the Humvee, same quirks as Sezziz10 had w/ body removal and so on but... did you notice the stand alone charger is using 3xAAA (4.5v) for 1 minute! Gets you thinking...how? why? and if you dual cell the thing how much too add if any? Of course now the dual celled Bit's have a pre man'd charger stand ready to go!
Old 03-13-2003, 02:12 AM
sessiz10's Avatar
sessiz10 sessiz10 is offline
Told ya.
The humvee I purchased is a bit bullet clone (bensu). The one you're talking about is most likely a motorworks car wich is more of a zcar clone. The reason I say this is because the bullet clone doesn't have a stand alone charger. It charges on the TX like most other bullet clones and only takes 2xAA.
This is what I purchased and where I purchased mine from.
http://www.toyeast.com/proddetail2.asp?pdtid=AC1291
____________________
Meh.
Old 03-14-2003, 06:58 AM
Gecko! not Geico...
here are a couple pics. Notice the tx still has a space for the pad.
Cannonball by Bensu w/ hazard cones and signs.
Old 03-14-2003, 07:00 AM
Gecko! not Geico...
here is the tx. The charger station uses 3xAAA btw.
Old 03-14-2003, 10:35 AM
sessiz10's Avatar
Told ya.
Thanks for the pics, that's the first time I've seen that.
Meh.
Old 03-14-2003, 09:51 PM
crazydave's Avatar
Garage Rocker
I have one of those Cannonball clones. It's not the Hummer, but the charge base and radio are identical.
The charge base on mine was only putting out 4.15 volts, with a fresh set of batteries that should have read 1.65. So it was losing a half a volt somewhere. I was also wondering if chargeing at a higher rate would make the car faster, but I found out that the battery only takes about 1.8 volts while chargeing, no matter how much you put into it, and always outputs 1.38 when fully charged. I also found that the base was giving the battery too much of a zap. The runtimes were around a minute, and performance was weak, but that same battery charged with 2 cells, and useing my volt meter to watch for the peak (about 4min.) runs for about 25 min., and is very punchy.
I also have a Motorworks car that has 3 cells in the charger, and does put out the full 4.5 volt. I put some overpriced, high output Rayovac Maximum Plus batteries in it, because they were the only ones I could find, and they blew the NiMH up the second time I charged it.
So 4.5 volts to charge one cell, is bad in my book. The slower you charge the battery, the better the performance, just as a generalized rule.
I really wanted one of those Chevy's BTW. Too bad they are out of stock. I hope they get more.
Crazy Dave's Crazy Car Gallery-It's crazy man, dig it.
Old 03-15-2003, 01:19 AM
ralliart's Avatar
ralliart ralliart is offline
i am po
Oh, i was just wondering if Bensu clones have alluminum rims? Because i was helping my friend fix his bit one day and the rim stuck to the magnet....i was soo amazed..
But i wanted to know ALL bensu clones are like that, or does anyone else have alluminum rims?
Old 03-15-2003, 03:50 AM
sessiz10's Avatar
Told ya.
Was the pin still in the rim and knuckle when you did this?
Meh.
Old 03-15-2003, 06:17 AM
Gecko! not Geico...
ralliart
Wanna buy a set of alum. rims w/ "steel" look finish?
Just kidding... you might want to edit your magnetic aluminum discovery.
Old 03-15-2003, 10:55 AM
ralliart's Avatar
i am po
sessiz10, yeah the knuckles and pins were with the rim when this happened...
Old 03-15-2003, 12:47 PM
sessiz10's Avatar
Told ya.
I think it might be the pin in the wheel attracting the magnet.
Meh.
