Old 09-28-2002, 02:47 PM
jets jets is offline
Originally posted by BaY oN AiM
i have a lowered front(springs) heightened rear(tires) 2.6 motor wit dual NiMH batts.
how long to you charge your batteries for? do you wheelie alot?
Old 09-28-2002, 03:28 PM
BaY oN AiM's Avatar
BaY oN AiM BaY oN AiM is offline
sLaNteD ViSiOnS
Send a message via AIM to BaY oN AiM
i removed the second battery...the wheelies cause to lift the front wheels off the ground thus i cant turn...
Modified controller: 3-4 minutes
Home made Stand alone 3 cell charger: 3 minutes
Home made plug in charger 3V: 2-3 minutes
"Nobody is perfect until you fall in love with them."
- Me
OH YEAH, GO KILL A BIRD!
Old 09-28-2002, 06:47 PM
QFM Racing's Avatar
QFM Racing QFM Racing is offline
Moderator - Modifier
Keep your wheelie bar low to solve the issue...
If your wheelie bar is low, once you wheelie, the bar will hit the ground, and bounce the car back onto its front tires quickly. This effectively solves the issue for straight line drags, BUT if you use the car on courses with many turns, or other than a standard oval and straight line, this will NOT fix your problems, because everytime you accelerate on turns and out of turns, the wheelie-ing will just send your car into the wall/barriers. The wheelie bar is really a BitDra-G mod.
FYI: ZipZaps fit 2 cells completely underneath the PCB, with only one modification (cutting out the latch area for charging port docking lock). The centered weight of the dual cells, negates the wheelie effect. There is a dual cell Bit mod that fits both cells beneath the PCB, but requires ALOT of chassis modification. The original cell is moved back and will actually sit over the rear axle well, allowing for more space for the second cell to fit (follow?). The finished product however hides the cells completely beneath the PCB with no cells exposed. Definitely advanced mod.
QFM Racing's Custom Bit Modifieds (The Bit How-To Page)
http://questformadness.com
Old 09-28-2002, 09:29 PM
JaMeZzZ122 JaMeZzZ122 is offline
Send a message via AIM to JaMeZzZ122
i'm workin on the dual battery mod now...whats the best gearing ad tire combo for bcg draging?
Old 09-28-2002, 09:33 PM
BaY oN AiM's Avatar
sLaNteD ViSiOnS
i would say the teal gear and the softest tires u can find....
- Me
Old 09-28-2002, 09:34 PM
blacksabbath070's Avatar
blacksabbath070 blacksabbath070 is offline
IRON MAN OF BIT RACING
ok thats easy
i believe the best gearing to use, that is if you are racing on 22 foot long track, would be 8.25:1 because although it doesnt accelerate as fast it reaches a higher top speed and to use soft tires
MY NEW CUSTOMIZED BIT:
red ae86 with zipzap spoiler
carbon fiber hood
3.8 motor (well, it doesnt want to run now)
qfm springs
back wheels on front and back
8.25:1 gearing
rare earth magnet steering
Old 09-28-2002, 09:36 PM
BaY oN AiM's Avatar
sLaNteD ViSiOnS
hahhahaha...
i beat u at replyin by a split second....
lol....
that was funny......
- Me
Old 09-28-2002, 09:39 PM
dang
DANG IT!!! hahahha oh well same reply you could have jsut siad that i thoguht of this too this would have saved me time
carbon fiber hood
qfm springs
8.25:1 gearing
Old 01-20-2003, 10:13 PM
BabyKiller's Avatar
k i have my 3:43:1 gears,r-spec,duel(mabey tri)cells on the way mabey if i can get 4 blue leds with a on/off switch(save power)i will mount each led in a corner or close to 1 under the body for a bottom and window glow effect its gonna kick ass and if i figer out how im gonna drop my car 2
+ (4.8v)
Old 01-22-2003, 12:59 PM
met-sb
a nice mod would probably be to replace the magnet with a circle of metal that way when u try to steer back in it goes slow and it doesnt get sent right of the track also i think it would work cuz the electromagnets atract metal to
Old 01-22-2003, 04:05 PM
dustn's Avatar
dustn dustn is offline
Poor Student
Send a message via AIM to dustn Send a message via Yahoo to dustn
I use kit racer front plastic whees/tires on the front spindles. I believe that they came from the RPM, MPH/KPH, and, I think, the ENERGI versions of KIT racers. They reduce rolling friction and steering. The steering is just enough to make the car easy to keep on line. By the way KIT racers are 3.88 clearance at my local Target.
Fight Crime <--> Shoot Back
Old 01-23-2003, 05:13 PM
MythosGR MythosGR is offline
One useful and easy mod is to use the pullback rear wheels!
They are wider and slightly smaller,for better acceleration and for 6-7 bucks you get another cool body and even front wheels if you want!
Plus some rims designs are kick ass!
just my 2 cents
Old 01-23-2003, 08:51 PM
RC_EVERYTHING's Avatar
RC_EVERYTHING RC_EVERYTHING is offline
Heres my drag car. I did the 2-cell mod and made the chassie about 1/2" longer so wheelies aren't a problem.The best part is now I can use slot car bodies on it with a little modifying.
MUST GO FASTER!!!!!
Old 01-23-2003, 08:54 PM
here's one with the body off
MUST GO FASTER!!!!!
Old 01-23-2003, 11:47 PM
~Bit+Racer+3~
A 2 engine, 4wd, Quad Cell mod would kick @$$ for BitDra-G. No steering, no wheelies. Perfecto!
Bit Char-G: FAQs (Updated: Jan 6th, '03) Namuna Bit Char-G / MicroSizers 15 08-14-2003 11:04 PM
Precious Clone... bit mods? djmr2 Bit Char-G / MicroSizers 4 02-07-2003 01:16 PM
some questions on bit char-g mods eman1 Bit Char-G / MicroSizers 29 12-17-2002 09:27 AM
Got my bit, what are some good mods? Chronic Bit Char-G Mods and Projects 3 09-14-2002 11:39 PM
