Old 02-25-2003, 05:31 PM
Napalm_Guru's Avatar
Napalm_Guru Napalm_Guru is offline
Wanna Drag??
Originally posted by Meltdown
Just added the gunflare mod.
I will make a new thread for it with scematics and photo's when all is documented.
I was just thinking about that...
My idea is using multiple LEDs and a 555 timer to make a explosian effect when you shoot. the power to the LEDs can be routed from the IR LED in the turret to recieve power.
And I was planing making a hole in the barrel to let light out.
Please explain your idea.
"Going to war without France is like going deer hunting without an accordion. You just leave a lot of useless noisy baggage behind.
-Jed Babbin
Old 02-25-2003, 07:02 PM
Meltdown's Avatar
Meltdown Meltdown is offline
Only thing needed is a BC547 smd transistor and a 2ma LOW CURRENT led.
The power of the Ir led alone won't do i tried.
The transistor will be triggered by the Ir led.
The transistor and led will be powered by the power cells (2.4v) inside the tank.
I already made it work great but i have to get me a smd transistor because
there's no room for the normal size transistor i used to experiment.
Full explanation will follow.
It's great to pull the trigger... the gun goes off with sound and flare while the tank recoils.
I'm loving this stuff!
Old 02-25-2003, 07:43 PM
Racemonster505's Avatar
Racemonster505 Racemonster505 is offline
Bit Nutz
Send a message via Yahoo to Racemonster505
meltdown are you planning and kits to sell so us (non-eletric) types can have a great mod?
"Im Not Crazy" Atleast That what the voices in my head tell me!
Fit Racer
Fit Racer
Old 02-25-2003, 07:59 PM
Meltdown's Avatar
I'm afraid that these mods are a little to involved to non electric people Sorry.
You will have to have more than average solder skills to pull these off, especially with smd stuff. The nature of these tanks makes them hard to mod because there's so little room. I'm a tech guy who has a smd solder station, lathe, build my own computer controlled mill and computer controlled telescope. These skills come in very handy for these mods. I feel for the non tech guys over here and wish i could help them. I would if i could. You could all come to holland and visit me for a mod and battle all day
Old 03-17-2003, 07:19 AM
Alard Alard is offline
Gun Flare mod
Any further info on the gun flare mod? How did it turn out?
Old 03-27-2003, 03:11 AM
Kadettcab Kadettcab is offline
@Meltdown:Where do you live in NL? You Know the Problem I have. Do you think you can help me?
Greets
Kadettcab
Old 03-27-2003, 03:51 AM
Meltdown's Avatar
Yo Kadettcab
I live in purmerend. It's 20km above amsterdam. Your problem seems to be of a more serious kind. I will help you ofcoarse if i can. Don't you have any warranty left? If you do it's best to send it in and get it replaced. If not than you can contact me off list using my profile to send me private email.
Alard
I will post the gunflare mod when time permits.
I've been so buisy lately...well you know.
Old 03-27-2003, 06:38 AM
Gun Flare mod, etc.
Thanks for the reply, Meltdown. Also am a tech guy. Have many ideas for modifications. Was thinking of using a light pipe for the cannon, with an LED in the turret for the gun flare. The pipes are available here .125" x 1.2". Then the LED could be surface mount or thru hole type.
When I get the chance, I will decode the tank and controller IR signals. This would allow to build a stand-alone decoder, which could make cannon sounds, etc. Structures could then be devised, that would respond to cannon attack.
Napalm Guru,
What sound pod?
Thanks,
Alard
Old 03-28-2003, 03:51 PM
Wanna Drag??
Helix describes it best here.
URL
-Jed Babbin
Old 03-28-2003, 09:02 PM
Squishy's Avatar
Squishy Squishy is offline
Quack
wow, alard, that woul be awsome to have houses, and bunkers that responded with the tanks! it would also be cool if you could make a buker that randomly fired. It would take combat to a new level!
Old 04-08-2003, 11:40 AM
Gun Flare mod, etc.
Still interested in how you did your gun flare mod, Meltdown. In particular, where did you put the LED and how did you wire the transistor?
I'm thinking of fabricating a new barrel from 3/32" or 1/8" styrene tube. Then using 1/16" or 3/32" acrylic rod as a core. The acrylic rod is available in clear, flourescent red, orange and green. The LED would be mounted inside the turret, the acrylic rod would conduct the light flashes through the barrel.
Haven't tried any of this yet. Need to do some experimenting.
After the gun flare mod is completed, will try to decode the infrared signals from the transmitter and the tank cannon. Hope to use that for external sound generation.
Old 04-08-2003, 11:55 AM
Meltdown's Avatar
Sorry for the late reply Alard!
I'm on tour with my band right now so i'm not at home.
But i've got my powerbook mac with me :-)
I will be back this weekend. Then i shall post the info next week. Also looking forward to the Ir decoding. Should be awesome. Later.
Old 07-14-2003, 03:34 PM
Tony A Tony A is offline
Gun flare
How about...small bore hole in barrel...fibre optic passed through...small led connected in some way to signal from fire/recoil connector on tank pcb...does this sound like sense?
Old 07-14-2003, 06:53 PM
Meltdown's Avatar
Yeah, that's the way i did it. I used a (very cheap) nylon E string for acoustic guitar as a fiber. This gives the best result. Much better than fishing wire due to the purety of the guitar string. Problem is that the electronics on the pcb won't allow you to drive another led. It will fry your pcb!!. I had to use a little cell and smd transistor to power the super strong white led i used.
Old 09-19-2003, 11:14 AM
arch2b's Avatar
arch2b arch2b is offline
TinyRC & Mini-zRacer Fan
curious to see the details of this mod, what became of this thread....
AWD with Resistor Mod for steering cool_cars XMODS Mods and Projects 20 12-04-2004 03:10 AM
Best Mod Contest (UNOFFICIAL) midget_man1387 Bit Char-G Mods and Projects 56 03-17-2003 10:38 PM
