Old 01-27-2003, 07:40 AM
scottyboyfun's Avatar
scottyboyfun scottyboyfun is offline
Im a cat, miow.
Send a message via Yahoo to scottyboyfun
a brass tube would be good,it wouldnt hinder the movement of the axle.
So what do u lot think?
Post it!
Old 01-27-2003, 07:53 AM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
i know that a metal tube would work best. the hard part is finding one that is the right diameter. you dont want it to be loose or the axle will wobble alover the place.
Old 01-27-2003, 07:56 AM
Im a cat, miow.
Try a rc model shop,My1 sells all sorts of tubing,right down to the small stuff.
Post it!
Old 01-27-2003, 07:57 AM
hogjowlz's Avatar
hmm. good idea.
Old 01-27-2003, 09:59 AM
crazydave's Avatar
Garage Rocker
Hogjowls, since you're already tearing your chassis apart, why don't you try this experiment for me.
Get a brass tube that fits the axel snugly, it's ok if it slows it down. (let me finish ) Get some bushing grease from your hobby shop. Green Slime is good stuff, but Associate, or Team Losi stuff is good. The key is the Teflon. Then take a spare axel, and put it in your drill. Coat it with thegrease, and spin it in the brass tube, to break it in like you'd break in a bushing. Then spray out he tube with motor spray, or WD-40 to clean out the metal you've worn away, and run your car with your axels greased.
See if that works. Should be super smooth, if it works out like when I broke in the bushings on my 1/10th scale cars
Dave
Crazy Dave's Crazy Car Gallery-It's crazy man, dig it.
Old 01-27-2003, 01:37 PM
hogjowlz's Avatar
that was the plan from the beginning. the hard part is finding a metal tube that is the right diameter. i dropped teflon in the plastic tube already.
Old 02-14-2003, 11:21 AM
Sid Sid is offline
how can the axles move if theyre stuck..?
45 MHz Nissan Gloria Bit Char-g
Custom Tires (back)
Medium tires (front)
TOMY Bit Racer 2.6 Motor
Old 02-14-2003, 02:32 PM
hogjowlz's Avatar
they aint. they are inside of a tube. why cant anyone read?
Old 02-14-2003, 06:41 PM
Im a cat, miow.
Does it run well hogs?
Post it!
Old 02-16-2003, 01:00 AM
Sid Sid is offline
ohh...
ohh..sorry..
Custom Tires (back)
Wheelies Ferreck ZipZaps 11 06-27-2003 09:35 PM
Straight wheelies Zephyranthes Bit Char-G / MicroSizers 3 02-26-2003 10:26 PM
Is it possible to do wheelies with a Panther clone? Sid Bit Char-G / MicroSizers 7 01-07-2003 05:35 AM
BIT Wheelies dabigpig Bit Char-G / MicroSizers 12 01-06-2003 10:53 PM
wheelies Ovgron Bit Char-G / MicroSizers 4 11-27-2002 11:43 PM
