01-14-2003, 10:22 PM
smoove operator
No problem biohazard, I'm glad you were able to figure out what step you missed in the re-scale.
Later,
B
01-14-2003, 10:43 PM
looks like i can spend money again phew. any ways thats a nice job very cool!
***  AMC Veteran  ***
-- ^-_-^
01-15-2003, 01:32 PM
Im a cat, miow.
How did u put in the extra gears? drilling a new hole in the chassis and placing a pin in it?
So what do u lot think?
Post it!
01-16-2003, 08:23 PM
extra gears pictures
Sorry for not responding sooner scottyboyfun. I didn't drill any new holes in the body for the new gears. I hope this picture helps you understand what I did to the body. Let me know if you have any questions.
01-16-2003, 08:27 PM
Bit Obessed...
where did you get those gears?
01-16-2003, 08:35 PM
Got Avatar?
That is wicked man, right along the lines of what i was thinking of trying. But I need help with steering and gearing. You should make a step by step tutorial, hehe
stil not sure about axels and stuff for mine.. only got the tires
***  AmC Certified  ***
01-16-2003, 08:39 PM
what gears
t-squared Which gears are you talking about. Give me a color?
01-16-2003, 08:43 PM
Swavey I am still working out some of the problems. Hopefully I will be able to simplify the process and then I will post step by step for all you guys if you want them. Let me know.
01-16-2003, 08:45 PM
Got Avatar?
Sweet, thanks a lot man, thats wicked work you got there,
im interested to see how my tires will work, very "rubbery" and "grippy" same size rim as the bit to i think, pretty much identical.
01-16-2003, 11:19 PM
Your steering doesn't look too sturdy...does the car turn?
01-17-2003, 01:41 AM
just cruisin by.....
i tried those same wheels on a truck mod but thet wre just too heavy. they tweeked my steering. i had to go with big matchbox plastic ones. worked much better.
muscle bound FREAK!
01-17-2003, 02:27 AM
Chunk
Secret to steering monster tires is to bring in the coils a bit closer to the magnet. You can also just wind thicker and more powerful coils. Someone here posted how to do that. Looked pretty easy. This still wont work on some, but it should work on the ones in the picture. The less rubber you have the better.
A religious war is like
children fighting over
who has the strongest
imaginary friend.
01-17-2003, 06:12 AM
Bit Obessed...
biohazard, what are those green and orange gears? do they affect your gear ratio?
and what are you using to hold the brass to the chassis?
01-17-2003, 04:16 PM
t-squared
The orange is standard microsizer gears and the green are standard zip zap gear. All these gears mesh very well (same gear ration). The front is straight brass bar placed through the holes for the old standard wheels, which I attached with a little glue. Two small screws hold on the back assembly. If you want later, I can post a picture. By the way, this truck will turn in both directions very well.
01-18-2003, 02:53 AM
Tool User
That is so incrediby cool!
I got really inspired yesterday to start making a DIRT-CHEAP version of your Monster-mod. And as I don't have brass tubing laying around the house where I can find it, I got creative. Yet I'm still completely ripping you off!! *what can you expect, I only have a ZZ, and bit clones*
My version requires:
1 grey plastic car holder base from a bullet clone (thing between car & battery cover)
1 metal dress-shirt clip (most brand use these instead of pins now)
1 plastic shafted Q-tip (usually pretty colors)
Atleast a partial bottle of CA or other suitable glue
A car you don't mind trashing a little
And a parts car, or pile of parts.
Tools:
Needle Files (Always gotta have them)
Cutters (I prefer Diagonal Side-Cuts)
Bent nose pliers
Chances are, you've got most if not all of this stuff laying around the house anyway.
The only thing I can't figure out is how to keep the stock position axle (gear) from trying to slide off the transfer gear. Do you make it to really tight tolerances, or just glue a spacer block on?
If there's anybody interested in this, I can explain in more detail. However, if the creator of this mod doesn't want me to, I won't tell. I respect that he can have a monopoly on it if he wants. *I'll try to find my dig camera if somebody can host pics for me*
