Go Back   TinyRC.com > Customer Support > bitchar-gmotors Customer Support
Old 10-03-2002, 02:17 AM
henry's Avatar
henry henry is offline
13B REW
hi i just broght a 3.0 and it doseint work good. i have to give it a tap so that it can move. i even pull the tab so its conect but it can not mov still. . i was wondering if i can have my replace? dose it mater if i broght from here or not?
Old 10-04-2002, 10:42 AM
tinyrc's Avatar
tinyrc tinyrc is offline
henry, I would check your gear mesh to make sure that everything is smooth first - does the motor run okay if you remove the rear axle? What gears are you using? BC-G/MS or clone?
Old 10-04-2002, 05:26 PM
henry's Avatar
13B REW
its a stock bit char-g that i barly broght and the moter is from bit racer. every thing runs ok wit the 1.0 motor but wheni used the 3.0, it stalls . i took off all the gears 2 see if the motor runs smooth but somtimez the motor dont go and somtimez it dose . so any solutions?
Old 10-04-2002, 06:02 PM
baleisen baleisen is offline
Micro R/C'er in Da Burgh
Send a message via AIM to baleisen
Send it back. Every motor I got from Tiny works. They just forgot about pinion gears.
A motor that isn't turning draws maximum current. This is bad. It heats up the motor weakening the magnet(s). This makes the motor run slower and take more current.
At this point I'll stick to TinyRC. If they screw up we can flame them right here.
Just my opinion. BAE
Smaller models, more control
3.8?? bjv5 Bit Char-G Mods and Projects 3 12-30-2002 09:08 PM
AAAARRRRRGGGGHHH!! STUPID 3.8 MOTORS!! (or was it my fault?) Chris Bit Char-G / MicroSizers 2 12-01-2002 08:20 PM
3.2 or 3.8 ZIZI ZipZaps 6 11-26-2002 06:47 PM
Dual Battery and 3.8? ax0n ZipZaps 14 10-09-2002 04:37 PM
