Old 01-11-2003, 10:33 AM
ClearStorm ClearStorm is offline
Team Mods Member
Send a message via AIM to ClearStorm
Well i have my dual setup already but was curious about the way you configured yours.
By the way what kind of tape do you use for your insulation?
Eclipse ZZ w/ Microsizer PCB:
Also: 2.8 DKS Motor, Red Gears
Coming Soon: Civic body with Full BodyKit, Muffler, and Underglow.
Old 01-11-2003, 11:25 AM
Nathan's Avatar
Nathan Nathan is offline
Bad Driver
Scotch tape, of course! I wired my charging plate to a 4AAA holder from radio shack. I just stick the car on and let it sit for a while to charge it.
Old 01-12-2003, 10:19 AM
sipsap's Avatar
sipsap sipsap is offline
Race them naked
did you ever figure out what was wrong with the batteries that you werent
getting any run time?
Old 01-12-2003, 12:03 PM
Team Mods Member
No, but i am thinking it is my insulation. I am using a bit of a paper cup. I am not sure if it is holding up. But the contacts points were sliding around. I have to fid a way to secure them.
BTW, will any tape work as an insulator?
Old 01-12-2003, 12:15 PM
sipsap's Avatar
Race them naked
i use electric tape as my insulator and my contacts were sliding around from doing the batt mod so i put them into place and put super glue on the bottom of the chassis on the front holes where you can see the contacts but the charger does not touch them
Old 01-12-2003, 12:49 PM
Team Mods Member
will any kind of tape work though?
Old 01-20-2003, 05:59 PM
Team Mods Member
OK, i have rewired my dual battery setup and i have modded the chargering process so that it bypasses the red light. I still have a prob. though. my problem is that the car works perfectly on the charger, but is dead when off the charger. any idea on what may be wrong.
I am confident that is is not my controller.
btw, i have a 3.0V custom charger
Old 01-21-2003, 03:23 PM
Wreck Inc 2
payaso edit: Last warning wreck...
Old 01-23-2003, 08:06 AM
Team Mods Member
anybody??
Old 01-23-2003, 03:29 PM
Bunta Bunta is offline
Hi ClearStorm,,,
You are almost there to 2 cell goodness,,,,,,
It sounds to me like there is a bad connection between the charging tabs to the 1st battery,,OR between the 1st and 2nd battery,,, OR between the 2nd battery and charging tab. The problem is one of your connections to the batteries.
The car works when it's on the charger because the charger's batteries are powering up the car,, and the NiMh cells are getting nothing (because of a bad connection somewhere). Remember that the PCB gets it's power directly from the charging contacts too.
just my .02
-Bunta
Custom Mods R us
Old 01-23-2003, 03:55 PM
Team Mods Member
Thanks a lot, i will redo all the connections, and your explanation makes perfect sense. btw. would you think the scotch tape would have anything to do with it?
I will tell you if it works in a few days.
Thanks again
Old 01-23-2003, 06:06 PM
Hi ClearStorm,,
I think scotch tape is one of the WORST insulators you can use. If you don't find any bad connections,, you could have a short circuit due to the scotch tape as an insulator. If this is the case,, your batteries will get hot really fast when you charge.
-Bunta
Custom Mods R us
Old 01-23-2003, 06:38 PM
Team Mods Member
What would you suggest other than electrical tape?
Old 01-23-2003, 10:26 PM
Hi ClearStorm,,
Will shrink wrap tubing fit where you need to insulate? If you want a quick and cheap fix you can probably tear up a match book and use the cardboard from the cover and wedge it in where you need insulation,, then tape it.
-Bunta
Custom Mods R us
Old 01-24-2003, 08:23 PM
Team Mods Member
It works without being on the charger, but the car is slower than usual and doesn't turn to the right, but i think i can fix it. Thanks for everything Bunta and everyone else.
More powerful steering for 2-cell mod? bonus: faster charging for dual battery mod Chris Bit Char-G Mods and Projects 1 11-23-2002 07:24 PM
My ZipZap now runs circles around my Bit! (dual batt success) caver01 ZipZaps 16 11-05-2002 11:22 AM
dual battery mod no speed increase? delmonk Bit Char-G Mods and Projects 7 10-17-2002 12:10 AM
ZZ Dual Battery Mod Mattydiah ZipZaps 1 10-14-2002 10:58 AM
