Old 12-17-2002, 05:28 PM
scottyboyfun's Avatar
scottyboyfun scottyboyfun is offline
Im a cat, miow.
Send a message via Yahoo to scottyboyfun
I was driving my bit char g alongside a bullet oem, n my 1 worked fine(tomy) but the oem did sometimes ignore controls, and when my tomy was right next to the oem, the oem moved opposite direction to ine (ie i was controlling it).
But the oem controls did not affect my tomy.
The oem was 49hz and my tomy 49Hz.
I know they're a similar frequency. But I believe the reason the oems have better ranges than the Tomy is because the Cars do not filter out weak signals, whereas the Tomy most likely does.
So the Tomy transmitter output mayb restricted (other than the cripple), and the car ignores signals under a certain strength (even w cripple removed).
So Tomy's could have better ranges, but b more susceptible to interference!!!!
So what do u lot think?
Post it!
Old 12-17-2002, 05:35 PM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
tahts true. my friends zcar(49) did that to my clone(27) which i found odd. so you think tomy puts a gate filter in their cars?
Old 12-17-2002, 05:46 PM
Im a cat, miow.
I think Tomy has done it purposely! After all, I m putting 2 ni-mhs in mine soon so it'll go super fast----BUT
These are designed to race on desktops, super fast cars nedd a long range, but then super fast cars fall off desktops, so I spose Tomy thought that a long range wouldn't b necessary!!!!
Ne way, im double ni-mh ing in, n we'll find a way 2 sort the range !!!!!
Small light and incredibly fast, this is gonna be a wooden floor racer!!!!!
(eventually)!!!!
I ordered 4 ni-hms today, 1.85 each!!!! 100mah
http://www.overlander.co.uk
And i've made my own charging tabs for the car using solder melted inside bluetack for a guide,then removed the tak!!!!
Post it!
smart range question rydzjunior XMODS Mods and Projects 0 03-03-2007 07:39 PM
ZZMT Remote Range 88-Fiero-GT ZipZaps Mods and Projects 1 10-09-2005 09:03 PM
Poor range kennylxix XMODS 7 12-22-2004 02:13 PM
Question about range 05WillysJeep ZipZaps Monster Truck 2 12-11-2004 04:43 PM
range of 27 MHz versus 49 MHz gRC ZipZaps 12 09-30-2002 06:33 PM
