Go Back   TinyRC.com > 1/24 and Smaller > Dynamite Rocket Racer > Dynamite Rocket Racer
Old 12-21-2002, 02:54 PM
Siress Siress is offline
Send a message via AIM to Siress
I always leave room for doubt but it was something he said that convinced me and I can't rember exactly what it was. I will get back to you all.
Old 12-22-2002, 10:14 AM
binaryterror's Avatar
Fear the 1's and 0's
Listen, no one wants to fight over a well known fact about mah.
I don't care what this guy says/said, he is wrong. Maybe you should consider him less than a genius.
Old 01-11-2003, 03:02 AM
rmyc's Avatar
rmyc rmyc is offline
Perfected Bit Modder
Exclamation
yall i'm backing up Siress ..but i kinda agree with the the other
Mah dosn't make the car go fast.. well kinda ..
lets put it like this.........
batteries with larger compacity usualy have a higher discharge rate.
thus., the motor would be able to suck more juice , and the car would go faster..
kinda like how nicad make the car go faster then nimh
but then again ,the larger the battey the more the weight which again slows the car..
i'll say they both are the same
Old 01-12-2003, 06:15 PM
fastboy fastboy is offline
im a micro daddy...
Send a message via Yahoo to fastboy
bigger mah DOES NOT mean a higher discharge rate.
it means it has more capacity and will deliver a set current discharge for alonger period.
a 700mah cell will not be quicker than a 300mah cell and vice versa.
what makes a cell turn a motor quick is having a low internal resistance and a high discharge voltage under load.
also having good quality connectors.
if you charge 2 identical packs but charge 1 at 100mah and 2nd at 500mah the 2nd pack will have more punch and will also be hotter at the end of a charge..not a good thing.
how do i know these things??...18yrs of electric r/c racing,trust me.
Old 01-12-2003, 06:46 PM
rmyc's Avatar
yah i know that but large batteries have a larger discharge rate.
trust me. that's why you have to charge small batteries at a lower mah.
Old 01-13-2003, 03:47 AM
im a micro daddy...
sorry but you are wrong about large batteries having better discharge rates.
ask stock racers which are the punchier batteries 2000mah or 2400mah..guess which they use,yep 2000mah.
if you compared say a watch batterie to a nicad then yes you are correct,but when it comes to aaa and aa then you will not notice a difference,the reason why aa may be quicker than aaa in your car is because you charge aa at a higher current which ultimately gives the batteries a higher discharge rate,the current at which a batterie is charged can make a tremendous difference trust me.
Old 01-16-2003, 06:36 AM
ag04 ag04 is offline
Send a message via AIM to ag04
my vote goes with fastboy... with my limited knowledge, fastboy has it all covered
ag04
Old 01-16-2003, 03:45 PM
Hicountry Hicountry is offline
fastboy
I have 16 years as a Navy Aircraft Electrician. 4 of those running a battery shop. Lead-acid and NiCD. You are right!!!
Everyone else read what he said and take it as gosphel. I could burry the sight in proof but that would take all the fun away. When you get payed to teach kids these things then argue with me, until then keep up the good work fastboy.
Hicountry out!
Dynamite Rocket Racer,180core,7.2v,13t pinion
Epoch Spd Rcr/Rcr X, #9 NASCAR
1/24 NASCAR Homebuilt
1/10th NMT Dodge
Need Help building HO TTTT
Old 01-16-2003, 04:34 PM
bigbamboo's Avatar
bigbamboo bigbamboo is offline
INTP
charge rate = discharge rate
SO does that mean a battery charged with a rapid charger (higher charge rate) will have a high discharge rate and improved performance? If so it'd be an atvantage to buy the quick charge vs a 12 hour charger.
I'm not science based. :-)
Bigbamboo
Old 01-16-2003, 06:31 PM
im a micro daddy...
yes it would be better to buy a fast charger rather than a 12hr trickle charger,altho you will experiance a shorter user life of the nicad,ie you may only get 100 good charges at a higher charge rate.
remember to buy a charger that is suitable for the cells you are charging,meaning dont buy a 4amp charger for charging 300mah AAA...THEY WONT LAST VERY LONG!!
ideally you want a charger that you can alter the charge rate right down to say 200mah.
for charging 250mah 2/3 AA use linear charge of 300mah.nomore.even then the cells do get warm quickly but not overwarm.
for700mah aaa i use 500mah charge rate,you could maybe use a little more but 500mah is plenty.
if you can get a small fan to keep the cells cool while charging then do so,it will help.
Old 01-16-2003, 06:53 PM
The pamphlet that came with my charger "in general" said to charge batteries at twice their capacity.
I dug up some manuals from work. It seems that the higher capacity the battery has the higher your charge rate can be in relation. ie 250mah probably 350mah is good, but a larger 2400mah pack can be charged at 5amps.
You must be careful because if a battery gets too hot it will go into thermal runaway and explode. Yes even these little cells.
We used to "overcharge" batteries at work if we had to get a jet out. It requires constant supervision because things can go bad quikly.
A good rule of thumb would be to charge batteries under 1ah at 150%.....1ah to 2ah at 175%.......2ah to 3.3ah at 200%
Remeber that a better quality matched pack can handle more.
1/10th NMT Dodge
Old 01-16-2003, 06:57 PM
Remember, no matter what general rule you follow, if the cells feel hot (not warm) then you are overcharging them. Back it down a little.
1/10th NMT Dodge
Old 01-16-2003, 08:08 PM
bigbamboo's Avatar
INTP
another battery thing
My wife uses 7.2volt stick batteries to charge her strobe on the camera. These batteries will provide for thousands of flashes and rather than recharge when they are already half charged, she rigged a car headlight to slowly drain the charge. I guess its to prevent memory from ruining the batteries. It seems to work for her.
FYI
Bigbamboo
Old 01-17-2003, 04:56 AM
im a micro daddy...
just remeber that with a car headlight bulb it will not stop when the batteries are flat and if all the cells are not a very good match some of the cells will be discharged before others sending some into cell reversal,in short a bulb is ok if you are there to take it off when the bulb starts dimming but can do more damage than good.
Holy shizzle TinyRC!!!!!!!!!!!!!!!!!!!!!!!!! xmodsman XMODS 34 04-13-2004 10:20 PM
holy..sh.. rmyc XMODS 10 02-12-2004 06:40 PM
Holy ****! Napalm_Guru Combat Digi Q 9 04-28-2003 05:58 PM
Holy! Look At This!! Ull Drop Dead!!! Alex TTTT 48 01-05-2003 05:10 PM
Holy Mods, Batman! johnrtse Bit Char-G / MicroSizers 4 12-12-2002 07:18 PM
