Old 10-31-2002, 01:20 AM
323iT's Avatar
323iT 323iT is offline
Send a message via AIM to 323iT
that happened to me cuz i drove my car off my table too many times but its just a crack and its still holding the heat sink in place
Old 10-31-2002, 05:33 PM
henry's Avatar
henry henry is offline
13B REW
thx 4 your replys guyz, so.. should i keep sticking my big zz motors in my bit? will that crak get bigger when i keep doin it? and i just got my 3.4 darkside rotor from driftking!its nice but kind of slower then the zz nos and turbo motor.
Old 11-01-2002, 02:47 AM
mustang_steve's Avatar
mustang_steve mustang_steve is offline
the "too many tires" guy
Send a message via Yahoo to mustang_steve
Thumbs up I have found the golden motor, and it was good, and i held i above all others....
hehe, got a NOS motor today, abnd that things has GOBS of torque, i was making it climb 50 degree plus inclines and it was taking it like a champ.
BTW henry, my advice to you is to not put the motors in without some kind of modification, whether it is chassis or motor (i do the motors, since they are cheaper ) You can, but i've seen the rear end tab split and wear prematurely from using a stock ZZ motor in a stock BCG motor area (my rx-7 is proof of that, and hte inspiration for my coming up with the motor mod)
heh i need to get new wire clippers, mine can barely cut the ZZ contacts anymore.
anywho, i noticed that the lower end ZZ motors are seemingly poor performers as far as torque goes, blue motors are just too slow, the green ones are ok for flat courses with tight corners, red is a nice all purpose engine (only an acceptable climber though), and hte yellow (NOS) motor is like heaven...so much torque alone that it wins me over, heh ive got to get a 1.6 to se if this thing can outclimb it.
If not, its still going to be one of my motors of choice.
Old 12-03-2002, 04:50 PM
DKS's Avatar
DKS DKS is offline
3.4 HENRY
Henry? did you say the 3.4 is slower than the NOS ZZ? THIS SHOULD NOT BE. Please let me know what setup you speak of
I need to know because If you bought a 3.4 with the ZZ enbell during our preorder for use in a Zip Zap, you are entitled to a replacement 2.8 which is MUCH faster. Our 3.4 ZZ motors were last minute built because during our 3.4 preorder for bits only, we realized that many people expected to use them in ZZ's- these 3.4 were not designed for ZZ's but we had the endbell style- unfortunately, they didnt work right in ZZ's. If this is the case, email me at driftkingshop@hotmail.com I will send you a free 2.8 replacement.
If you are using a Bit Style 3.4 in the ZZ, this may explain the slowness. Only our 2.8 has been tested to be faster in a ZZ
REMEMBER- our 3.4 are car-Specific! Using a Bit one in a ZZ will not work or vice versa. Please contact me. I want my customers to be happy with DKS motors!
I don't know what car/3.4 setup you refer to in your post, but it should NOT be slower! I will point you in the right direction!
driftkingshop.com
DKS 3.4 Darkside, 2 cell equipped NSX
27 MHZ
Old 12-03-2002, 05:17 PM
henry's Avatar
13B REW
i used it in my bit, its all stock.its slow in acceleration,but it slowly gets faster then my nos i think. my nos is qricker. is it supost to be way faster then nos? or a little? cuz i think its a little faster.
Is this normal? RSXRacer001 XMODS 10 01-01-2004 05:00 PM
Turret Insides and Motor Behavior - Is this normal? Bistromatic Combat Digi Q 0 10-17-2003 04:09 PM
Sold Pro Microsizer Bought A Normal One 2G2SILVERSTRAT Bit Char-G / MicroSizers 5 07-04-2003 10:31 PM
Is this normal? bjv5 Epoch RC1/43 3 04-05-2003 01:42 PM
Special editon gearing vrs normal gearing Smurf Bit Char-G Parts and Hop-Ups 2 10-09-2002 11:08 AM
