Old 02-11-2005, 09:12 AM
rssjib rssjib is offline
Too many XMODS
Good info, Devryn...Those resistors are easy to wire into the servo wires. Those things that you need to solder on the board are too damn small. You would have to have excellent soldering skills for that.
Thanks again.
RSSJIB
(2) Yellow Skyline GT-R: AWD, AtomicMods 180S motor, Li-Ion, CF driveshaft, suspension, bearings
(2) Black Skyline GT-R: AWD, Stage2 motor, Li-Ion, suspension, bearings
'04 Mustang: AWD, AtomicMods SS130 motor, Li-Ion, suspension, bearings
C5 Corvette: AtomicMods SS130 motor, Li-Ion, suspension, bearings
C5 Corvette: stocker
(3) STi WRX: AWD, CF chassis, AtomicMods SS130, bearings, body kit, Li-Ions coming
Black RSX: AWD, Stage2 motor, suspension, bearings
Silver RSX: stocker
Red Supra: AWD, Stage2 motor, suspension, bearings
Silver Supra: body kit, Li-Ions soon
(2) 350Z: body kit, Li-Ions soon
NSX: body kit, Li-Ions soon
'65 Mustang: body kit, Li-Ions soon
_________________________
"rehab is for quitters"
Old 02-11-2005, 09:58 AM
Devryn Devryn is offline
No problem. I got the fix from another board, so I can't take any credit.
http://www.xmodworld.com
Warning though, there are alot of newbs there, and they can get really really annoying.
Old 02-12-2005, 01:56 AM
I have a beach ball...
Originally posted by moddog
I got some 3.3K CFT (old style) ones to put in line with the servo pots as well for those not looking to get a 180 motor. If you have a 180 motor, replace the ones on the PCB only.
Where did you get this info? I have a 180 motor in my Mustang with the inline resistors, and it works fine.
'65 Ford Mustang
All the RS goodies
Becoming a donor car for:
'04 Ford Mustang Cobra
Old 02-12-2005, 10:41 PM
moddog moddog is offline
Oh, I'm not saying they won't work, just saying the ones I got were quite big and there was no way the ones I had were going to fit with the 180. I'm going to use the 3.3K ohm SMDs inline with the servo pot. At least it will put those to use.
Old 03-16-2005, 06:05 PM
Horshu Horshu is offline
Obsessive Modder
Anyone know offhand if Fry's or comparable stores sell 472 SMD resistors? I guess I could always order the kit from AtomicMods, but I was doing some XMODS errands tomorrow anyway so I figured if I could pick them up somewhere to go ahead and get a bunch of those, too.
Old 03-20-2005, 01:20 PM
Obsessive Modder
Figured "to hell with it" and ordered the AtomicMods resistors. There are 3 to a pack, and I got 2, so really, I can do 3 ESCs. I practiced soldering some spares of the same size (about 1.25mm by .75mm...REAL small), and it went remarkably well, getting a very tiny but complete dab of solder on each side. The trick was to tape half of it down to solder one side, then do the other once it's secured. Took a split second dab with the iron tip set at ~280 degrees C. Actually was harder getting the originals off than putting the new ones on.
Old 03-20-2005, 01:49 PM
dragon4450's Avatar
dragon4450 dragon4450 is offline
customanix
Send a message via AIM to dragon4450
hey guys i just want to post again that i have the 2.7k resistors. i'm selling them for $2 shipped for 2 resistors. you can e-mail me or hit me up on aim.
and then we added the giggle gas.
Old 03-21-2005, 05:29 PM
Obsessive Modder
Put the surface mount version of tight turns into my car. Damn, what a difference! That almost doubled the steering range.
It actually wound up being much easier than I expected. I cranked up my soldering iron to 290 degrees Celsius. I then lightly pressed the tip against an edge of the existing resistor. It comes off in a half second or so. Next, I get some thin masking tape (scotch is too rigid), cover half the new resistor, and secure it to the board. Next, I got some RS silver-bearing solder (.015" diameter, 62/36/2), lowered the temp down to 270 degrees or even less. Put the tip on the pad in front, touch the solder on it and push in a touch of it and take both off. The actual act of soldering is literally done in a moment. Do that 4 times, and you're done. I also got my newly designed wire layout in there, using very minimalize wiring that I prebent, so my ESC is officially done pending a final range check. For those intimidated by surface mount board work, it's actually much easier than I expected it to be.
Old 07-06-2005, 07:28 AM
Sounds like to need to re-center your servo. The easiest way is to adjust it via the controller, but there is a way to take apart the servo to center it permanently.
question about the suspension and steering upgrade kit LightFetish XMODS 1 01-30-2006 11:48 AM
WOW, another steering discovery! Upgraded steering motor! cyborgzero ZipZaps SE 2 02-22-2004 12:16 PM
I went and bought the Steering & suspension upgrade. FrozenKamikaze XMODS 10 12-10-2003 08:53 PM
Suspension and steering upgrade dEmOnRaCeR XMODS 5 10-19-2003 12:02 AM
