Old 01-25-2005, 12:22 AM
I have a beach ball...
Nitrogen is NOT FLAMMABLE. It is an inert gas, which means that it does not react to anything. Not fire, not temperature, and not any other chemical.
When nitrous oxide is injected into a running engine, the heat of the combustion causes the nitrous oxide molecules to split into two nitrogen atoms and one oxygen atom. This extra oxygen (which is extremely flammable), when mixed with additional fuel, causes a hotter combustion cycle. The two nitrogen atoms go out with the exhaust, totally unburnt. The flames that are associated with nitrous have nothing to do with it at all. They usually happen because you suddenly let off the throttle, which turns off the nitrous instantly, but not the extra fuel, which will still be injected into the engine for a split second. This extra fuel causes a sudden rich condition and sends a lot of raw fuel into the hot exhaust, which then ignites, causing a flame to shoot out of the exhaust.
'65 Ford Mustang
All the RS goodies
Becoming a donor car for:
'04 Ford Mustang Cobra
Old 01-25-2005, 10:53 AM
ChenPokoMasteR's Avatar
ChenPokoMasteR ChenPokoMasteR is offline
A Winner Is You
Send a message via AIM to ChenPokoMasteR
Yeah, what he said
350Z- Cf Drive shaft, Custom motor ( 40T, bbcan, Neo mags), Cf drive shaft, Awd, bearings
Skyline- Cf Drive shaft, stacked fets, 2 cell lithium, AWD, Bearings, Custom motor
Old 01-25-2005, 09:58 PM
RacinSkillZ101's Avatar
RacinSkillZ101 RacinSkillZ101 is offline
Banned
Send a message via AIM to RacinSkillZ101 Send a message via Yahoo to RacinSkillZ101
yup Murcielago659 ur right bout the whole thing (which is y i said an oxygenator) if memory serves propane can be added to ur fuel (like nitrous is added) and that adds more fuel to the combustion.
in autos we learned how leaed fuel has a high octane (resistance to knocking, useful for high boost/ nitrous applicatinos) and was cheaper than current gas... what im trying to do is locate a leaded gasoline source.. and to the tree huggers, screw the enviorment its damned weather i pollute or not
and finally with the whole flame and exhaust thingy, i honetly would install nitrous or an agressive cam to acheive flame, but if they occur thats fine
Old 01-25-2005, 11:23 PM
Or you could get a Mazda Rotary powered vehicle and remove the cats and install straight thru mufflers.
'65 Ford Mustang
All the RS goodies
sharper image hummer rt144 Bit Char-G / MicroSizers 11 01-01-2003 04:34 PM
Sharper image car jerm781 Bit Char-G / MicroSizers 0 11-15-2002 12:22 AM
