10-29-2004, 09:41 PM
10-30-2004, 07:26 PM
BitPimp
hey bodie,
nice plane!
i was wondering, do you have 4 AA batteries in your controller? And if so did you mod the electrics? And what did you use for the fuselage, wings, and prop?
Whack!
10-30-2004, 08:43 PM
The extra pack attached to the back of the receiver is the added 2 cells making it a 4 cell Tx.
I replaced the transistors of the right/left outputs with mosfets capable of handling 1 amp which is used to power the motor.
The existing forward/reverse outputs are used to drive the actuator.
The airframe is made from 2mm depron foam. Plans came from E-Flight.com.
The prop is an GWS 2.5x1 of which can be bought here.
http://www.eflightdesigns.com/cgi-bi...cts.cgi?CAT=22
All info is in the links I posted earlier in this thread. All the needed information is in the links I posted if one wants to research it as I did.
Mainly this one, of which I will post again.
http://www.rcgroups.com/links/index.php?id=4392
10-31-2004, 01:33 PM
iPod therefore iAm
Somebody over at ausmicro said that 39 newton per meter for a bit-sized motor was bs, and that a 500cc motorbike engine would be expected to put out that much torque. I have no clue what these numbers mean, and would like to know if 39 newton per meter is too high for a bit-sized motor.
10-31-2004, 03:54 PM
You may be able to find the conversion factors here.
This site comes in handy.
http://www.onlineconversion.com/
12-02-2004, 02:32 PM
Xmodder
OK, either the people that told you that were wrong, or they were telling you the scale power of the motor? lol, just a guess
EDIT: Ok, nvm, i just found out that 39 newtons = about 9 pounds of force, but newtons per meter? hmm
*Nissan 350z*[COLOR=royal blue]
-Stage 2 red SB hybrid motor (soon to be neo mags, BB can and BB endbell)
-IC-3 800 mAH bats - 4 cell
-AWD
-Blue springs up front, silver in back
-Aluminum locknuts at all four corners
-Locked rear diff for drift action![/color]
