Old 06-09-2004, 10:00 PM
viperdout's Avatar
It's Really Fast!
Dude, with the voltage he wants to run, you need it. When I ran my xmod at 15 volts RWD, all I'd do is fishtail, and I'd have to let off. Let's face it, most of the time you're not gonna have good conditions, and AWD will own. If you have a really grippy surface, AWD will be owned. But I certainly don't have good grip anywhere with RWD. AWD is just better for the type of racing done. Top speed is better RWD, but for a 1/4 mile, with both cars weighing the same, same hp, same everything except RWD and AWD, AWD will beat it, hands down. It's been tested by car magazines, and it's true.
Project Bad Brushless:
Just say no to giant sigs.
Old 06-09-2004, 10:42 PM
ax0n
I didn't see that he was upgrading cells. For things like the atomicmods 8.4v Li-Ion or V1 conversion, yes, you'll pretty much need AWD. You're correct there.
If you'll read my first really long post, it's about getting the most out of an XMODS with only official parts and hop-ups (which is what mine is like right now) and I can tell you that until you do excessive voltage stuff, you're wasting your time with AWD unless you're on a crappy surface.
Old 06-10-2004, 12:16 PM
adiosk8r13 adiosk8r13 is offline
im capital 1"s CE NO!!!
make sure you lock up the differential by taking it out and putting clay in between the gears in the differential and then it should have the same amount of power at both of the wheels
if you have ever stared into a can of
orange juice because it said concentrate you might be a redneck...
Old 02-03-2005, 02:45 PM
broke ess supra broke ess supra is offline
also if you have trouble with going strait(straitest path is shortest) especially if you are using rwd with a high powered motor its best to put hard slicks in the front and soft slicks in the back...once you get a certain speed you can't steer very much so you go straiter...oh and you can also put your steering trim down too
i believe rwd is the best setup too...look at all the top fuel dragsters they all use rwd and they do like 5-6 second 1/4 miles
a monoshock helps you get traction in the rear end because it keeps the tires flat on the ground unlike the stock ones
I actually use a monoshock that is crazy glued together on very flat surfaces so the rear tires don't even move....this setup allows me to run a 5 cell with a stage 2 motor(sb mags, timing advance weight reduced armature, 11t) and kill like all my friends
oh did i mentioned i don't even use a drive shaft....check out this pic of what i use it doesn't even spin just doesn't let the gear dislodge at all...i can't go in reverse though so it ain't for regular racing.
oh it doesn't weight anything...ala whittled golf tee...hehe
Old 02-05-2005, 10:10 AM
viperdout's Avatar
It's Really Fast!
Broke ess, where in NJ are you?
Old 02-07-2005, 05:52 PM
in old bridge, middlesex county
My Car doesn't work! Eyemfaster XMODS 2 03-02-2005 10:59 PM
Digi Propo Special Codes vs Settings keal Digi Q 15 11-06-2003 10:22 PM
my drag car 4 trade zombiebaby For Sale/Trade 5 01-25-2003 02:35 PM
What gears and motor should I use to get the most power out of my car with a trailer. AudiTF Bit Char-G / MicroSizers 6 11-14-2002 05:38 PM
Cat5 vs Cat5E for car antenna material mechanist ZipZaps 6 10-13-2002 01:59 AM
