Old 07-13-2004, 02:16 PM
micro kid's Avatar
micro kid micro kid is offline
Do you getto dremel?
just a headsup if you run a rear swaybar you'll want a front too otherwise when the wieght transferst to the front corner i'll pick up the rear wheel and make it diff out.
racing on pavement is for wussies.
Old 07-14-2004, 12:33 AM
spinitsidewayz!'s Avatar
spinitsidewayz! spinitsidewayz! is offline
boro dori style RC
do you tighten it all the way? cause you dont want it to lock..mines fine it pushes the inside rear down as the outside compresses f.
shift drift: in a way it is but the trishock pushes the suspension outward and the bar holds it together. i would say it helps preload the springs sorta...
r34 - rwd
r34 - awd
dd4 - fwd
Old 07-14-2004, 02:58 PM
micro kid's Avatar
my suspension is locked whe the weight transfers to the front during a corner it lifts the inside rear
Old 07-15-2004, 12:33 AM
boro dori style RC
you want to loosen it so the joints can swivel freely. that should help solve youre problem. an limited slip diff would work too
r34 - rwd
r34 - awd
dd4 - fwd
Old 07-15-2004, 02:35 AM
micro kid's Avatar
i had a locker setup for the stock diff that i was going to post after some more tests and im glad i tested it further because it screwed it self up. im starting a new version tonight.
Old 07-20-2004, 11:07 AM
viperdout's Avatar
It's Really Fast!
If you used a very thin piece of plastic, it would still flew, yet would still have suspension.
Project Bad Brushless:
Just say no to giant sigs.
Old 07-21-2004, 02:11 AM
boro dori style RC
thats what im running now. the packaging for upgrade parts
r34 - rwd
r34 - awd
dd4 - fwd
rear sway bad m_pastier Micro-T Parts and Hop-Ups 5 02-12-2007 07:03 PM
Solved KIT rear issue...... DarkTari Bit Char-G / MicroSizers 0 02-10-2003 10:48 AM
whoa, Taiyo rear is removable, meaning: CUSTOM T BAR REAR SUPSENSION MOD TIME!!! MTL Auldey (All) 6 12-30-2002 07:53 PM
Sway bar kit w/Axle JrC Bit Char-G / MicroSizers 2 10-17-2002 12:54 AM
