01-28-2004, 09:20 AM
R34 Skyline is God
Well first off, what are the comms?
My Bit: Phast motor  (Orange)
Soon to come:  (Undecided) Custom Rims
01-28-2004, 09:35 AM
Its the metal tabs that the wires are connected to, there are three of them.
01-28-2004, 09:43 AM
R34 Skyline is God
Ok I think I got some of this down.
Solder one end of the wire to a comm
Wrap wire around one section
Solder wire to next comm
Wrap wire
And so on.
01-28-2004, 04:06 PM
Yeah, just remember the order of winding...
Start with a comm, solder the wire, wind it around the leg to the right in a counterclockwise fashion, and bring the wire to the next comm to the right of the leg you were winding and keep repeating that process until you are finished.
Thats the order for 130s, 180s are slightly different.
01-28-2004, 05:59 PM
I'm confused ... do you put the total number of winds on one leg, then move to the next leg?
Almost sounds like you are doing the whole motor with one continuous wire too. Is that right?
I may open up another motor to put in some more SB magnets tonight. I'll have to take a closer look at how it's wound...  I'd love to get into this winding stuff, but dont wanna screw jank up
Sliver Xmods Skyline
SB hybrid S1 drift motor - Yay doughnuts!
01-28-2004, 08:09 PM
R34 Skyline is God
You solder the wire to each comm, right?
01-31-2004, 03:00 PM
If you are winding from scratch, use one wire.
You will be soldering wire to each comm, however, it may be the same wire.
If you are just doing the easy "cut-n-paste" method to unwind a few turns on the legs. You will have cut 1 wire into 3, but the connection is still there when you solder the wires back to the comms.
01-31-2004, 04:37 PM
just dont loose count of the winds,i did that plenty of times,then had to unwind it
