Go Back   TinyRC.com > 1/24 and Smaller > XMODS > XMODS Science
Old 01-20-2004, 11:16 PM
Exaran's Avatar
Exaran Exaran is offline
Send a message via AIM to Exaran
Look on the "top" side of the motor (The side with the lable). You are looking at the top of the "U" so you should just see the ends of the clip sticking out past the magnets. I know I'm not saying it well, but I dont have a motor apart right now to take pics.
It's basically between the two magnets against the top of the can.
Sliver Xmods Skyline
SB hybrid S1 drift motor - Yay doughnuts!
Old 01-21-2004, 01:11 AM
spitty12's Avatar
spitty12 spitty12 is offline
Happiness is a warm gun..
Send a message via AIM to spitty12
This works great, I did it to a stage 2 motor with 5th cell and 8 tooth and the car absolutely flies. Throttle modulation is key though, most find my car almost undrivable because it will just spin unless you are light on the trigger.
What pinion pullers are you guys using? I broke a $13 one on the first pull.
I use a needle to get the U pin out to the point where I can grab it with pliers.
Old 01-27-2004, 04:33 PM
Bash_N_Thrash Bash_N_Thrash is offline
I tried this mod on a Stage 1 white motor (stocker). I reversed the magnets as per the directions but after installing everthing had the motor spinning backward problems. So I took it all apart and swaped them left for right and it worked correctly. I must say this setup has lots of low end and could probably climb a steep grade, but top speed is terrible. Also I noticed that with the motor connected to the cars electrical and in my had that it had a higher top speed in reverse than in forward. Do the magnets have any effect on that? I will be taking the magnets out and installing them in a stage 2 red to see how that works.
Old 01-27-2004, 08:22 PM
RC 2NR RC 2NR is offline
TinyRC XModder
You could try advancing the timing to get a higher top speed in foreward.
For Sale:
|XMod :: Black Supra|
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
-Wheel & Tire upgrade
-All Wheel Drive Kit
-Ball Bearing Upgrade
[url]
Old 01-28-2004, 11:32 AM
Ya I am going to give that a try as soon as I swap out everything. I think the combo I will try next is PN racing BB can with Stage 2 armature with advanced timing, SBP magnets, and either the Stage 2 end bell or the BB can (I havent compared the brushes yet). I will say that even though I have bean disappointed in my efforts so far, at least I'm having fun.
Old 01-29-2004, 12:53 AM
Exaran's Avatar
I just did my yellow motor tonight and I paid better attention to things...
----DO NOT REVERSE THE MAGNETS LIKE I SAID BEFORE---
Just put the magnets in the side they came from, and everything should work fine.
I also took pics of the whole thing, just gotta get em up here
Old 01-29-2004, 07:41 AM
TinyRC XModder
Yeah, I noticed that too.
For Sale:
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
[url]
Old 01-30-2004, 09:15 PM
Exaran's Avatar
Heres pics!!!!
First, the brush!
Old 01-30-2004, 09:30 PM
Exaran's Avatar
prying up the tabs on the can
Exaran's Avatar
seperating the brushes from the endcap
Old 01-30-2004, 09:31 PM
Exaran's Avatar
the motor with the cap off
Old 01-30-2004, 09:32 PM
Exaran's Avatar
the brushes pulled back. The ends of the "U" clip are circled in red
Old 01-30-2004, 09:33 PM
Exaran's Avatar
pulling out the "U" clip
Old 01-30-2004, 09:34 PM
Exaran's Avatar
Pulling out the magnets
Old 01-30-2004, 09:35 PM
Exaran's Avatar
Magnets ready to be swapped
Pinion Removal SupraFreak00 XMODS Parts and Hop-Ups 1 06-09-2004 01:18 PM
Pinion Removal ? webpilot XMODS Mods and Projects 13 12-04-2003 07:48 PM
Magnet source for improved steering mod DesertJedi Bit Char-G Parts and Hop-Ups 1 10-29-2002 05:19 PM
