Closed Thread
Old 12-31-2003, 09:12 AM
geofroley's Avatar
geofroley geofroley is offline
R34 Skyline is God
Send a message via AIM to geofroley
When I was 11, I was down in my basement melting action figures with my soldering iron. It was the end of 5th grade for me and I was celebrating. Then somehow I burned myself and the top of my index finger looked like a skin colored lizard scale. Needless to say, I was swearing like a mofo.
My Bit: Phast motor (Orange)
Soon to come: (Undecided) Custom Rims
  #17
Old 12-31-2003, 09:27 AM
lemans23's Avatar
lemans23 lemans23 is offline
GT3 Drift Master
lol thats hilarious. i didn't even know what a soldering iron was until 7th grade!
Bit Char-G= FRIED WITH 4.0 MOTOR
RSX XMOD:
Stage 2 yellow motor
.5 cm
Hard slick rear
hard tread front
5 cells
ALL ALKALINE
  #18
Old 12-31-2003, 11:55 AM
Rez Rez is offline
Send a message via ICQ to Rez Send a message via AIM to Rez
Christ almighty that sounds painfull. Condolences.
Rez
a7i20ci7y
Seven Cities RC
  #19
Old 12-31-2003, 12:12 PM
geofroley's Avatar
R34 Skyline is God
Thanks but I got over it. It looks like it was never there now.
  #20
Old 01-19-2004, 07:37 PM
Spike88DS's Avatar
Spike88DS Spike88DS is offline
My MoMmY SaYs Im SpEcIaL
Send a message via AIM to Spike88DS
Originally posted by Comrade_Boris
ya...i posted in the other thread you had about this......also be carefull with x-acto knives.......i went to the bone on my 2nd finger on my left hand.......no stitches, but a nasty scar..........that was while working on my black bB MS..........
ya do be careful with x-acto knives i cut my self 5 times in the same day while triming extra crap off my model mustang
just say to your self when you get mad what would jesus would do....then say to your self wait y are you talking to your self
  #21
Old 01-20-2004, 10:40 PM
suprafreak33 suprafreak33 is offline
got supra?
wow, if u didnt learn from that Plastic smells really bad
but as long as u dont burn your self on a wood burning kit cus,
solder iron = 500f
wood burn kit = 900f
note this is about temp.
xmod
blue supra
6 cell
all upgrades[by rs]
  #22
Old 01-21-2004, 09:03 AM
neurokinetik's Avatar
Mad Scientist
Originally posted by suprafreak33
solder iron = 500f
Not my soldering iron... it is adjustable from 350-850, and I normally use it around 750.
  #23
Old 01-22-2004, 12:17 PM
ninja828 ninja828 is offline
....i burnt my upper lip w/ my soldering iron once.....luckily the burn mark was there a total of two days.....so just remember: dont sneeze while you have a soldering iron in your hand while it close to your face!....then within the next two weeks i sliced off a small chunk of my flesh w/ an exacto knife, sliced into my right pointer finger to the bone, and repeatedly stabbed myself with the exacto knife (which i didn't really mind after have sliced into my fingers previously). now, there is a small blood stain on the inside of my supra shell and i can say with much truth: i put my BLOOD and sweat into modding my xmod!
  #24
Old 01-22-2004, 04:28 PM
duwain
same thing happened to me, but the blade didnt go to the bone. i was makin a model and sliced off a piece of my skin, and it hurt so stinkin bad. now i have a nice scar tho , jk
btw i think we should make this into a stories about bad things that have happened while doing things with sharp edges and things that are hot when something went wrong thread. lol
  #25
Old 01-23-2004, 08:24 AM
aperson's Avatar
aperson aperson is offline
I'm not a pyro, really.
Originally posted by Joey
[b]When I wore glasses, I'd chip the lenses up to the point that they were all but useless for vision correction after a few weeks. I shouldn't even be allowed around Dremels.
same here. i dont have to use an old set when im working in my "shop"
NEVER UNDERESTIMATE THE POWER
  #26
Old 01-24-2004, 07:07 PM
sinistar sinistar is offline
E-xacto and file nonos
Ok I have cut my finger tips several times with fresh out of the pack blades and right now I have on my left hand two needle size pricks which still draw blood and refuse to close up due to the small size of the holes or should I say finger pricks from the doctors office. I found out a way to combat these bothersome things which plague mine and others lives. I put super glue on the cuts after they have been closed up a bit and the bleeding can be stoped from getting on your finger. And another thing to if you ever do any filling that uses a bigger file than a regular hobby size file take a piece of electrical tape and put a band of it around your finger or part where the file would rub and actually let the file gently rub the tape region as aposed to letting the file slip off the working surface and obtaining a even worse cut by the file by the way the file will grate into your finger/hand part and make a worse cut due to the particles that are on the file or finger will sting due to the germs that plague the file from it's raw operation of scraping across whatever it comes across. My nuckles and ends of my fingers have all had a taste with this and i use latex gloves if I'm going to be painting or just tape if it's minior work. I hope none of you get any of these.
Sinistar
question #6 is now ready out of the
toaster and has popped up for you.
  #27
Old 01-25-2004, 08:13 PM
aperson's Avatar
Re: E-xacto and file nonos
Sinistar
wow! i ve had all of those accidents. instead of superglue i use the Liquid Bandage
  #28
Old 02-02-2004, 07:14 PM
Savior*insider Savior*insider is offline
ARRRG! that patch makes you look just like a pirate! i am so envious...
all u need is a parrot.
I am the insider, i kno all
current xmod stats: everything. i got the hook up =P
  #29
Old 02-02-2004, 07:22 PM
I Shall Return!
dude that aint nice, he almost went blind..
  #30
Old 02-06-2004, 08:56 PM
viperdout's Avatar
It's Really Fast!
One time I was using a Dremel with the pointy tip, and it slipped and I stabbed my hand. I immediatly turned it off. The weird thing was, no blood came out but it hurt so bad. It scabbed over, but I still have a red mark from it.
Closed Thread
warning do NOT goto Xmodworld.com right now.... Draconious XMODS 27 06-23-2006 06:00 PM
Austin Martin DB5 body issue (a warning & a fix) rc+bass ZipZaps SE 13 05-23-2006 12:19 AM
Ok, Just Stumbled in Here, I am Hooked where to Start?? TOTAL NEWBIE WARNING!!!! Ziptar TTTT 3 12-19-2005 12:37 PM
Low Voltage Warning Light Rez XMODS Mods and Projects 3 02-06-2004 11:42 AM
Springs: WARNING gek Bit Char-G Mods and Projects 3 11-29-2002 02:29 PM
