12-30-2003, 08:32 PM
Is that actually feasible?
These cars are already really packed with the technology they've got, especially around the motor, it'd be awfully hard to make a gear hand-off mechanism. I assume it'd have to be an automatic, too.
Mazda Savanna RX-7
stage 2 motor | spaced wheels
12-30-2003, 08:35 PM
put the drift motor back in an control ur speed an the amount of power thruout the turn its not easy and put somethin on the floor spray pledge on it that works best for me on hardwood but its dangerous for anyone who walks on the floor with socks because its so slippery smells good tho
awd does help alot
12-31-2003, 12:04 AM
"Umm I need a new car"
tape use tape u tape your wheel happy heh jk bout the happ.we there you go
12-31-2003, 12:22 AM
GT3 Drift Master
can someone tell me what the hell this means?
Bit Char-G= FRIED WITH 4.0 MOTOR
RSX XMOD:
Stage 2 yellow motor
.5 cm
Hard slick rear
hard tread front
5 cells
ALL ALKALINE
12-31-2003, 10:55 AM
DRIFT KING
put tape on your wheels like a said before, just use masking tape instead of any other tape because you can get traction and drift when you want too, just make sure you rrun it a bunch on concrete, like a garage floor, then the tape works really good.
I don't care if you can you beat me in a drag, I'll own you in a drift match.
12-31-2003, 11:27 AM
RC Tinkerer
Foam Rubber wheels are great for smooth surfaces. Traction on straightaways, and slip on the turns.
12-31-2003, 11:55 AM
DRIFT KING
i haven't tried those yet, but i prolly won't get them, yet.
12-31-2003, 12:07 PM
RC Tinkerer
I had to return an AWD kit, one of the front wheel studs was too short. While I was there I figured why not, $7.99, I'd give ti a try.
The Foam Rubber Tire Kit is different than the other tires. There is no ridge in the middle of the rims. The foam rubber is heald on with Double Stick Tape. However you may be able to use other tires with these rims.
12-31-2003, 08:26 PM
GT3 Drift Master
dude, maikeru. i know ur the drift master. i know a bunch about drifting, but not as much as u. but ur masking tape method, it doesn't work for me. do u have any other methods? can u post ur full set up down to the last thing?
RSX XMOD:
.5 cm
Hard slick rear
hard tread front
5 cells
ALL ALKALINE
