Old 03-04-2007, 02:18 AM
hotrod29728's Avatar
God I know this is an old thread but, for the noobs, buy either the IC-3's for the instant rechargeability 15mins tops or go for the more expensive yet way more powerful Li-Ion or Li-Poly batts from www.atomicxmods.com they have some badass batteries for decent prices. Also www.batteryspace.com has some good deals on batts too. Just get a decent charger. That should give you some more top speed/ acceleration. Also for your range, DO NOT WORK ON THE CAR WITH THE BATTERIES IN IT! If you happen to touch the antenna to the battery or the motor you are likely to short out the diode for the antenna and will have 5-10ft range on it compaired to the normal 15-20ft range. Hope this helps you guys. -Josh
Current XMods:
Black Skyline: Stage II Motor
Current Microsizers:
Current Zip Zaps:
Black 68 Camaro SS
Red 25th Anniversary Camaro
Black Chevelle SS SE
Mazda RX-7 SE
Mazda RX-7 SE
Silver Pontiac Trans Am
Orange Mustang SE
problems with old xmod yellow15092 XMODS 0 06-25-2006 02:39 PM
which xmod has the least amount of problems? stampede XMODS 6 01-25-2004 04:24 PM
XMOD Problems, HELP.!. rplpt XMODS 3 01-03-2004 03:05 PM
