Go Back   TinyRC.com > 1/64 and Smaller > Yokomo Puchi Maru > Yokomo Puchi Maru
Old 12-31-2003, 03:55 PM
dgilpin dgilpin is offline
This is the side with the tension screw. The screw tightens against a ball bearing.
Old 12-31-2003, 03:57 PM
With the screw and one half removed, exposing the spur, balls, and one plate.
Old 12-31-2003, 03:58 PM
And with the spur removed showing both plates.
Old 01-01-2004, 04:49 PM
Shooterb Shooterb is offline
Thanks dgilpin!
Excellent pictures!
The one I've made soaks up more torque than I'd like and I'm trying to figure away to improve this. Does really improve cornering, but at the cost of serious acceleration. Your pictures have already suggested an improvement: locate 6 balls (instead of 3) farther out, .25" instead of the .17".
Still, I think I need more tension. Perhaps if I could get even the inner plate magnetic...
Thanks,
Brett
Old 01-02-2004, 10:08 PM
Whatup1049
ncredible work, how do you make such tiny stuff? What tools do you use? I hope once you get a final prototype you sell those cause I would buy one!
Old 01-22-2004, 04:26 PM
cheesehead cheesehead is offline
Location: The land of all things faster than they need to be.
I'm a shade confused, but I think I get the general idea.
Why not use a 3-gear differential? With 2 gears with horizontal teeth (facing each other) and a 3rd gear spinning freely between them, it would work great. You spin 3rd gear, which spins the other gears in turn. If one side slows down, the center gear adjusts the other one up. And you would get nearly no loss of torque with gears.
You can see what I mean with the LEGO diff-same idea.
Of course, you would have to be a clockmaker to get the gears to mesh....
Ninja Burger: Your burger in 30 minutes or less, or we commit seppuku!
Old 01-22-2004, 04:39 PM
strakka's Avatar
strakka strakka is offline
AA member
Send a message via ICQ to strakka Send a message via AIM to strakka Send a message via Yahoo to strakka
your probably rite ... when you get this small a 3 gear diff would probably be better (like a Bit Char-G) but Yokomo made this car based on larger RC cars. thats probably why its a 2 gear diff
dNaNo Ball Diff LBRC Kyosho dNaNo Parts and Hop-Ups 3 07-04-2008 10:53 AM
Wanted: Front Ball Diff for mRS4 k_bojar Micro RS4 - YourMicro.com 0 04-07-2006 12:42 PM
The Ball Differential: LSD, USD, or LGD? Turnination Guy XMODS Parts and Hop-Ups 0 02-03-2005 12:29 AM
Is the rear ball diff adjustable? eetoi XMODS Parts and Hop-Ups 14 04-04-2004 01:59 PM
Dam Diff........ fatdoggy Dynamite Rocket Racer 2 01-22-2003 09:25 PM
