Go Back   TinyRC.com > 1/24 and Smaller > Mini-X > Mini-X Parts and Hop-Ups
Old 12-26-2003, 12:33 PM
diets diets is offline
@lowam
I tried a servo as well, but i decided to use modified dogbones. There is not enough room for a big servo at my crawler, because of the extreme possible articulation. How much is the articulation in your setting?
How did you mount the steering servo. Just with tape? And what type of servo do you use? Look's like the so called 'micro' size, similar to the Hitec HS81. I use a smaller one, size is similar to the HS55. It is a GWS NARO with ball bearings, it is strong enough to do the steering, even the car stands still. I tried different servo, but i would recommend the GWS, best of all, it's the cheapest I found.
diets - powered by lipoly soon
Old 12-26-2003, 04:04 PM
lowam lowam is offline
i can put the left front tire up 2 in, and the rear right tire up 2 in. at the same time or vice versa. as for the steering servo i had to cut L-brackets out of aluminum beasuse i couldnt get any tape to stick to the top of the diff casing. i used a hs81 hitec servo. it has plenty enough power to turn the wheels and its only about $20.00.
''if you want to feel funky. feel free!but please dont get that funk on me.''
Rock Crawler p4tch For Sale/Trade 6 07-28-2006 02:37 PM
how do u make an xmod h2 a rock crawler crazyone XMODS 2 12-29-2005 02:59 PM
1/24 Rock Crawler bluemonster TTTT 4 01-08-2005 12:27 AM
Check Out my custom MINI Rock crawler Maxxcrazy Other Tiny RCs 6 09-22-2003 06:59 PM
just about to order mini z or mini x but have a question tarnjit Mini-X 0 12-22-2002 10:01 AM
