12-07-2003, 01:37 AM
Proud to be Pinoy :)
Originally posted by Timbo337
And thats for the 1/87 joint? Sounds really hard. I don't think I can even buy metric drillbits here in US.... but I'll look
:ö: nope, that u-joint is for 1/30th scale and is suitable for real micro off-roading!... though my 1/87 u-joint design is a bit different from that! but it's pretty strong because i made it out of steel  .
hehehe
12-07-2003, 09:41 AM
yeah im using a pistol grip and i was right it was the battery pack. it does the same thing on my 1/10 when the battery starts to die. i but the batterys seem to last longer in my 1/10. oh well i plan on having my 1/30ish "dune buggy" done by then end of this week. if i get time to work on it. ill keep yall posted and show pics when im done. and this truck does not use a u joint anywhere, it is 2wd and uses a gear box out of a $2 "RC" from wal-mart.
12-07-2003, 03:04 PM
well after getting the gearbox on with all the electronics it doesnt look much like a lean fast dune buggy, more like an overweight car with no suspension. the reason i didnt put suspension was because any spring i put would probably bottem out from the weight of the electronics.
12-08-2003, 03:29 PM
Pics
-Tim
mtb=beast
12-08-2003, 04:44 PM
heres one pic. the things comming out of the front wheels are the bolts holding them on. i will cut them to the proper length when i get the car working.
12-08-2003, 04:45 PM
woops
forgot the pic
12-08-2003, 04:47 PM
side view
12-08-2003, 04:49 PM
last one
12-08-2003, 05:28 PM
:ö: try using smaller or micro servo... it'll save you a lot of space  -æ
hehehe
12-08-2003, 05:34 PM
try giving it a larger ride height and wider wheelbase, just my 2cents
If i was atacked by a rancid 5 legged monkey, i would put him in the fridge until he clamed down. Then i would ask him what happens to the light when you shut the door.
12-08-2003, 05:36 PM
the reason i made it like this is because the total cost of the truck was about $3 for a peice of 1/4" metal bar and everything else i had. i am having trouble with the mico servo speed control. when i turn the car on and hit the gas the car turns left and goes fast. and when it stops its does a back and forth dance thing across the floor. i have adjusted the trim and the little thing on the servo and nothing happens. have any of yall had this problem?
EDIT: i have desoldered the servo motor and attached a more powerful one. could this be the problem?
12-08-2003, 05:44 PM
 hey! you can't use a micro servo board to run a 130 type motor!!!!. -æ
hehehe
12-08-2003, 05:58 PM
huh? the motor im using is from the cheap rc i got the gearbox from. it works fine when i plug it into the steering in another rc of mine to test it but when i put it with the battery box and receiver it goes nuts.
12-08-2003, 06:12 PM
what killer is saying is that that motor is still to large for the micro servo speed control, its drawing to may amps and the reciever begins to act like its got a low battery, you need a more standard speed control or a smaller motor.
12-09-2003, 05:21 PM
Hack into that big servo, and use its board as the esc, and then reassemble the micro servo to use as the steering  Does it articulate at all? Looks good!
-Tim
mtb=beast
