01-14-2004, 02:25 PM
Got Brains?
hot hot hot
Mine stopped running last night, so when I opened it up to find out why, the heatsink burned my finger. I thought maybe it overheated since I had just went from s2 yellow to blue, but it turned out the batteries in the roof had come a little loose.
This is your brain.....
01-14-2004, 06:13 PM
Umm.. Teal Rsx
i've seen some with the fins chopped off, does it serve any perpose, i don't think it would any opinons?
01-15-2004, 11:24 AM
Got Brains?
no
The fins are needed to help dissipate the heat.
01-15-2004, 06:17 PM
Umm.. Teal Rsx
and i've seen them like, half the motor holder is cut off and the heat snik is still there
01-15-2004, 08:42 PM
That would theoretically cool it better, but that leaves the motor open to any kind of airborne debris that could screw it up.
Mazda Savanna RX-7
stage 2 motor | spaced wheels
01-17-2004, 07:59 AM
--PCB smoker--
heatsink
A computer ram or heatsink cut to fit would work well. That would provide the optimuim cooling efficency. I would lap(sand) the top of the motor starting with about 400 grit then gradually work your way up to a 2000grit paper, leaving no high or lowspots in the motors can top surface. Then I would sand the contact surface area of the heatsink the same.
I would use a thermal epoxy, a thermal epoxy like they use for CPU heatsinks, not a thermal paste, but the epoxy and i think Artic Silver makes an epoxy as well.
The stock heatsink sits tight but it is not a efficent transfer or dissapation.
01-17-2004, 11:33 AM
I agree.
G35 rolling chassis
H2 rolling chassis
Cobra,rolling chassis
red Supra SOLD
65' Mustang...SOLD
Corvette... SOLD
WRX...SOLD
blue Civic...SOLD
01-19-2004, 09:48 AM
Track Master
I thought about using thermal paste as well but was concerned with the dirt and dust and gunk that gets into everything when you run it outdoors.
And youd need to put a separate sink on each motor you used most likely, as removing the sink each time would waste the goop and make the risk of getting it elsewhere as well as getting dust in it higher.
Might be interesting to test the life of the motors w and w/o heat sink to see how long they last.
01-19-2004, 12:05 PM
The heatsink isn't all that necessary with a factory RadioShack Stage 1 or 2 even on carpet with higher gearing and AWD. I don't believe that even in those conditions, the motor will heat enough for a loss in magnetic field to a point where its noticable in the cars performance.
When you start running a motor with a higher energy draw or a higher voltage power source, you will want to address keeping the motor cool. IMO the factory unmod'd RadioShack goodies aren't enough to worry about.
