11-08-2003, 11:41 AM
Originally posted by digiman32
Hey BC
Can you give us a diagram of how exactly that you wired it all up? I have already picked up a battery holder and I am ready to but it in, but want to be sure of the wiring before I do.
I am interested too...where did you wire it in....
11-08-2003, 12:00 PM
Yeah, let me draw it up.
11-08-2003, 12:03 PM
Mad Scientist
Alright, you've convinced me.
11-08-2003, 12:07 PM
Convinced you of what?
11-08-2003, 12:27 PM
Looking from the rear of the car to follow diagram. Find the black wire running from the bottom (negative) post on the left side over to the bottom (positive) post on the right side. Cut it in the middle and strip the ends. Next splice the left side wire to the red positive going to the extra battery pack. Then splice the black negative on the battery pack to the right side wire. Your done.
11-08-2003, 12:57 PM
Thanks BC!
Current Xmod:
Skyline GT-R w/Custom Vinyl Graphics, AWD, Stage 2 - Drag, Bearings , Tires, Wheels, Med/Stiff Springs, 3.0 Toe In, Lights
RSX - AWD, Stage 2 - Drag, Bearings, Med/Stiff Springs, Tires, Wheels, 3.0 Toe In, Lights, 6-Cell Mod
11-08-2003, 01:16 PM
Got 4.2 King? I do : )
what did you have to do to the body to get it to fit?, i'm running a skyline
MY XMOD!
Yellow skyline
Springs: Hard all around
1.5 degree toe in
hard slicks
Top Speed stage 2 motor
full bearings
AWD
6 spoke wheel upgrade
energizer rechargeables
6 Cell Upgrade
11-08-2003, 01:36 PM
got boost?
looks like it's not that hard to do it
am i right?
All Wheel Drive=Fun!!!
11-08-2003, 01:42 PM
so you put pos to neg on one side and neg to pos on the other?
11-08-2003, 02:01 PM
"Its OK I had subway"
hey bc did u just take the connector from the motor
11-08-2003, 02:21 PM
yeah instructions would be very helpful. what does the xtra battery pack clip into
11-08-2003, 03:20 PM
I robbed a quick connect from a chassis I was using for spare parts. To get the body to fit (Supra at least), I had to cut out some of the strengthening bars on the mounting tab in the rear, so I could slide the battery pack all the way up against it. I also had to remove the light kit mounts. I then used one of the bushings and a longer screw, and stuck the bushing between the black part of the mounting tab and the body where it screws into. This gives the body enough clearance to have the heat sink on the motors, and still fit. I then hot glued the battery pack in place.
This may not work for all bodies though.
The directions for wiring it up are in the post before the diagram.
11-08-2003, 03:21 PM
Bushing...
11-08-2003, 04:30 PM
I need to change my Title
I tried it and the motor stopped owrking. I am going to check the batts, but it does notihng except for steer. I also axidently melted the stock batt holder. Sh!t, the warrenty doesnt cover"melting batery holder"
4 Bit Char-g Failiers
1 Microsizer
3.8 motor
Duel Cell sucess
Celica body
11-08-2003, 04:42 PM
You must have crossed something somewhere.
