11-08-2003, 01:43 AM
well my 2 cents for adding a body would be to hook up sum of those hearing aid batteries (size and weight) to the top and then make a jumper so u dont have to use them all the time, due to not being rechargeable and all.... or u could get sum more of those zip zap batteries (since u kno how much volts it can take now so try differnt types of batteries to see if you can get size down with a rechargeable battery... thats what i would do if i had a job to pay for this if i broke it, LOL
11-08-2003, 06:20 PM
xmod destroyer
how did you get that clip thing like that also could you make a step by step tutorial
11-08-2003, 06:28 PM
The clip came from the motor and chassis clip from another chassis which is being used for parts. You can use sta-cons too, which are sorta like quick connects you can get at RS. I will do a tutorial when I do one for the AWD car.
11-09-2003, 05:41 AM
My question is, when is someone gonna try a pair of 9v batteries?
Aww, yeah, 18v of power...
*car goes really fast for about 1 sec, than explodes in a hiuge fireball*
Umm, it's actually CommanderMcBride. I didn't notice that it didn't fit......
11-09-2003, 10:37 AM
For what it's worth, I gave a pair of lithium polymer cells a shot last night and all I can say is WOW! 8.4V fresh off a charge, 7.2 nominal and lighter than 4 AAA cells. THe stock electronics seemed to take it in stride although I can't be too sure that I am loosing some power due to overloading the thing (= heat).
I removed the stock battery holders and used double sided foam tape to hold one on each side of the chassis. The body fits too.
I should warn you though that if you discharge these batteries below 3V per cell they will be ruined. So I have to work on a cutoff circuit.
These things are cool, but don't tell the owner (my son) I said so.
11-11-2003, 10:58 AM
Supra king
6 AAA mod
I got mine to fit like a champ in my supra body. I am going to take some pics and start a thread when I get home tonight
**1997 Supra Xmod**
-Stage 10 Motor w/11 tooth
-AWD
-Wild body w/ Custom paint
-6 AAA battery mod (7.2v)
-Double head/tail light mod (Not used with 6 cell)
-Hard suspension w/ 4.5 toe-in
-upgraded wheels with hard tires
-Metal bearings upgrade
11-11-2003, 04:14 PM
Supra king
Quick dis-connect
I did mine kind of cheap. I had a old motherboard with fan. I pulled the fan header off the board and cut the wire off the fan. Whala.. a quick disconnect. If you dont have spare parts lying around I would check Radio shack or a hardware store. They would definetly have something to make one
**1997 Supra Xmod**
-AWD
11-11-2003, 04:22 PM
My quick connect came from a spare chassis and a stock motor, but you should be able to find something else if you look at any electronics store.
11-12-2003, 04:25 AM
Xmod Skyline
X Speed Mini Z Motor
9 tooth Drag gears
6 cell mod
AWD
Blue (stiff) Rear Suspention
Red (soft) Front Suspention
Hard Slicks all around
RS Bearing Set
11-12-2003, 12:05 PM
Supra king
Heres my little setup
I spaced my batteries out a little more
**1997 Supra Xmod**
-AWD
11-12-2003, 08:16 PM
Hey BC......How are you liking the Stage 10 Motor?
11-12-2003, 08:56 PM
I don't have one yet...and at the price he is asking, I might not get one. This thing goes fast enough for me......for now. Besides, I need to save my money for Emaxx hop ups.....now those are expensive!
11-12-2003, 08:59 PM
"Its OK I had subway"
hey bc do u have a micro rs4 do u or anybody recommend themand a place to buy them.
11-12-2003, 11:37 PM
Originally posted by Jakillo
So is the supra the best body to use in order to fit 6 cells? And also can I Sodder the wires together?
i fit 6 under my gtr
