Old 07-11-2005, 01:42 PM
Capt.ArD Capt.ArD is offline
yeah, i've tried doing it, but i hit some problems (see thread in xmods section on extended axels). To tell the truth, it depends on what you want to do that dictates how you need to mod. big tires destroy your torque, so i would recommend using a Spinbrush motor at least. just the tires and the motor will get you to run on sand or Very small gravel. anything bigger will catch the bottom of your car and it will sit there and happily spin its wheels.
if you want to hit large gravel, rock-crawl or hill climb, big tires area must, and maybe a fet mod and definitely a VERY torquey motor. I will be using a Cassete player motor. (only about 3000 rpm, but more torque than you know what to do with, runs on stock fets.)
i have a Plate lsd in the back and the ball in the front with the big tires and a SB motor. i was working on a new susp. to get about 1" of ride, which would be suitable for climbing or big gravel, but it sorta died. (again, see my other thread.)
i think if you want to waterproof it, you could just wrap up in ceram wrap, letting the wheels out through little holes. cheap but better than nothing. dust is not much of an issue, just clean it out after every use. hope i helped
skyline, black
Spinbrush motor with capacitor mod, 10-tooth pinion, blue spings, 3.0 tie rod, lego tires, AWD. Plastic driveshaft.
rally!
Old 08-22-2007, 10:45 AM
cadillacman1213 cadillacman1213 is offline
Thumbs up
i heard that if u just hot glue the ventholes in the motherboard cover, it will water proof it ,(not to boat statous) but close enough for mudding
Old 08-22-2007, 01:37 PM
fatman's Avatar
fatman fatman is offline
yes
but can fry chip
if its not broke i can fix it
offroad upgrade on evo cars The Red Titan XMODS Parts and Hop-Ups 1 04-04-2007 04:03 AM
noob here,, has anyone actually tried making an offroad track jaejw1 ZipZaps Monster Truck 21 01-13-2006 06:25 AM
my 1/24 offroad project sawhit4 Other Tiny RCs 2 11-10-2004 04:37 PM
looking for 1/10th scale offroad Ovgron For Sale/Trade 5 06-30-2003 12:39 AM
Micro offroad tires Stridex Bit Char-G / MicroSizers 50 02-04-2003 07:31 PM
