Old 10-29-2003, 05:03 PM
TwizteD TwizteD is offline
Send a message via AIM to TwizteD Send a message via Yahoo to TwizteD
amagine the stage 2 with that mod
Old 10-29-2003, 07:09 PM
baleisen baleisen is offline
Micro R/C'er in Da Burgh
Send a message via AIM to baleisen
AWD + Stage 2.
I did just this. I went full mod and the yellow stage 2 gear set. Stiff shocks in the back, medium in the front. I haven't changed the tyres yet. They will be soft treads in back and hard treads in front. In the mean time this rocks. BAE
Smaller models, more control
Old 10-29-2003, 08:07 PM
catman25 catman25 is offline
where can we put the extra batts/?Any one have a mothod that doesnt look stupid?
Old 10-30-2003, 09:28 AM
hydroscrog hydroscrog is offline
Send a message via Yahoo to hydroscrog
supra
one can find room to put one or two cells on the rear bumper if one made a plug to disconect the body from the chassis
Old 10-30-2003, 12:42 PM
xalex0000 xalex0000 is offline
This is Neat !
I like thi xmod car thier pretty cool. Im myself a miniz Mr02 owner. . Im pretty sure you could burn out the electronics on a mini-z if you put 7.2 volts through it. wont the 7.2 v Mod on the X-mod fry the electronics ? Dude because if its not im running to one of those xmod AWD Cars !! You could probably beat some micro rs4 with that thing !
Old 10-30-2003, 04:15 PM
Nugget210 Nugget210 is offline
good news, but bad news
i ran over to my local RS and got a 2 aaa bater holder, so i got home, hooked it up, faster than it ever was before
but (theres a but)
it cant go in reverse
so im pretty sure the extra volts disable the ecs on it
too bad it seems like a good mod for it
Old 10-30-2003, 04:29 PM
Chris's Avatar
Chris Chris is offline
Send a message via AIM to Chris
Are you sure? I have the same set up (two extra cells) and the car still has reverse and everything. No fried electronics, either. and about beating a micro RS4, there's no way . I have a micro RS4 with a pan chassis and a 380 motor , 7.2 V battery pack, and the thing is ridiculously fast. but it might be able to beat a stock micro RS4 if thats what you were talking about......
when you've tried everything and you still lose, there is only one answer, NOS
Old 10-30-2003, 05:38 PM
Got 4.2 King? I do : )
where did you mount it? i want to do this but cant find room under the stock skyline
MY XMOD!
Yellow skyline
Springs: Hard all around
1.5 degree toe in
hard slicks
Top Speed stage 2 motor
full bearings
AWD
6 spoke wheel upgrade
energizer rechargeables
6 Cell Upgrade
Old 10-30-2003, 06:19 PM
Chris's Avatar
It doesn't fit under the body. I think someone else said you can get a AAA holder that holds 3 AAAs and it fits under the body with a little trimming of the body (with a dremel tool I guess) but otherwise they don't really fit under the body
Old 10-30-2003, 06:50 PM
-CRX-
im not understanding the picture. were does the red wire run to? do you just hook up the black wire to the battery? then to the spring in the tray?
also i have the skyline with the stage 2 motor with the blue gear, just wondering if this mod is gonna blow my sh*t up?
Old 10-30-2003, 07:48 PM
-CRX-
http://www.radioshack.com/product.as...5Fid=270%2D414
just wondering if this would work? and were would i hook up the 2 wires?
Old 10-30-2003, 08:19 PM
Chris's Avatar
That should work, and even if it doen't, it's only $1.49 . I don't really see and reason for the extra cells to blow anything up (although the extra voltage is possibly dangerous to the esc, I haven't had any problems at all) and the red wire is attatched to the contact where the negative side of the battery would normally touch (its a little spring). The electrical tape shown is to block the current between the negative side of the battery and the red wire.
Old 10-30-2003, 09:03 PM
-CRX-
now were does the red wire coming from the battery holder hook up to?
Old 10-31-2003, 02:30 PM
Chris's Avatar
it hooks up to the negative side of the extra cell
Old 10-31-2003, 05:52 PM
Geckoboy Geckoboy is offline
hey i got a question about the batteries
is a 3.8v battery with 600mah that is recharable good?
would two of them would work in an xmod without fring anything?
