Old 05-23-2003, 05:42 PM
jedclampit jedclampit is offline
Send a message via Yahoo to jedclampit
doods, for the steering thing I just pick the car up, and if it's not turning one way-- but you still here a faint clicking sound when you press the button then something is interfering with the mechanism eh?
usually the steering rack getting hung up on something, or the white things that hold the front wheel axles (they have burrs on them from the factory sometimes)--just take it all apart and lightly sand all surfaces with some 200 or 400 grit wet/dry paper. Or even the wheels getting hung up on the car body. I had one car with a totally worthless suspension bar allowing the front wheel axle holders (whatever their tech name is) to travel all the way up to the top thus hindering turning.
people are right in this thread, it wouldn't be the return spring, if that's not working the car simply doesn't return to neutral, but flick the wheels a little and see if the return spring is bringing the wheels to neutral? however there could be a slight chance it came off one or the other post thus forcing the steering to one side.
Just adding to the mess is all, peace out!
Old 05-23-2003, 09:35 PM
Heat's Avatar
Heat Heat is offline
Zhuge Liang - My Idol
i just fiddle with the white thing on the bottom it tends to fix everything for me. if that dont work try opening the front end and putting the white tab in the middle and notice how the white shaft is. once mine was all twisted even tho the tab was in the middle so i untwisted it and it fixed the steering a lot. also is your racing surface clean? slants? cuz i've never had this problem before. and what tires u got on cuz i'm thinking hards will give you trouble when you're using a perfection on a smooth surface.
Old 05-24-2003, 08:47 PM
Tillek Tillek is offline
What about the steering coils? Could maybe they not be putting out/getting enough juice to attract the magnet to one side? I can't figure out why my little 350z doesn't turn one direction very well either.
What are the Must Mods for Xmods? HappyPillZ XMODS 17 02-08-2005 07:42 PM
list of mods and my collection Skurge420 XMODS 12 12-07-2004 03:00 PM
