04-27-2005, 06:05 PM
With optional solderable AA Li_ion battery holders
04-27-2005, 06:11 PM
Or for prebuilt Li-Ion kits, simply use double sided tape or your choice of cable tie fitments.
Li-Poly cells should fit flat across if you can clear the drive axle.
2/3A cells are also a possibility...........
Dremel the chassis to fit your needs..........
04-27-2005, 06:20 PM
Shipping this week to the shop:
CF X-Frame Pro 1.5 Stock Kits
Red Tex X-Frame Pro 1.5 stock Kits
CF X+ Flat Pan Chassis Pro 1.5 kits
Red Tex X+ Flat Pan Chassis Pro 1.5 Kits
04-27-2005, 07:20 PM
X-FRAME PRO 1.5 STOCK,RED TEX
04-27-2005, 07:21 PM
BOTTOM
04-28-2005, 09:26 PM
soo...no upperdeck/pro mod kit for the pan chassis? aftermarket electronics may be a problem to mount.i may have to reconsider purchasing the pan chassis...
are 2/3a really posible?!? it would be kool to use gp1100's in an xmod.their like the best for 1/18 cars.
later
imChinOaChickeN
-imChinOaChickeN-
04-28-2005, 09:32 PM
Obsessive Modder
Zero,
You think you're gonna do another line of the silver chassis? I like the new, smoother clearcoat on these red chassis' you have.
04-28-2005, 09:53 PM
It's Really Fast!
Zero, just as an idea, if you used a longer piece with holes that ran to end end of the subframe on the short setting, it'd make fitting 1:24 scale bodies on simple as hell.
Project Bad Brushless:
Just say no to giant sigs.
04-28-2005, 10:07 PM
nice ideas all...............
It is very hard to fit the micro electronics in with the the center battery deck, fit my Supra but not the RSX-Mustang-350Z. its a little simpler when you Dbl-Sd tape to the batts and push those wires into the cavities. And working with just 2 aa's is somewhat easier.
Probably won't make another run in silver Tex as I am having to buy a full sheet to get the good stuff and at $350 bucks a pop, well you can see the economics.
Hadn't thought of extending the rear of the chassis, but you could buy 2 and give it a try or make your own extension and bolt it in place.
Thanks for the input
04-29-2005, 02:19 PM
It's Really Fast!
Zero, as another idea, you could make an extension that would bolt down where the rear deck was, then the deck would bolt to that. Since you use washers, it'd take the place of them.
05-02-2005, 11:21 PM
are you going to at least sell the pro mod upgrade kit like before for the pro stock kit?the one that came with the upperdeck and servo mount.i would like to mount the mini-z/nelly turbo electronics on it so im able to switch batteries without much hasle.maybe it can be in something not carbon fiber t not short the electronics out or something like fiberglass or something.thanks
later
imChinOaChickeN
-imChinOaChickeN-
05-06-2005, 08:32 PM
For anyone that is interested i just got an e-mail from tinyrc stating the CF chassis came in today and should be available this weekend.
05-10-2005, 01:17 PM
When will it be on sale? know how much it will cost?
05-10-2005, 06:06 PM
Should be any day now, David is probably trying to find the time to get them listed............
05-13-2005, 03:26 PM
Dang! so much excitement! I cant wait much longer for it to come out.
