Go Back   TinyRC.com > 1/24 and Smaller > XMODS > XMODS Science
Old 02-10-2004, 05:19 PM
scatmanjohn01 scatmanjohn01 is offline
so there should only be 4 wires going to the external board from where the stock motor fets used to be?
Old 02-10-2004, 06:35 PM
ninja828 ninja828 is offline
scatmanjohn01 posted
yep, thats correct
hey neuro, how's the reg/fet combo mod progressing?
Old 02-10-2004, 09:56 PM
another question, neuro, can i keep the stock fets on, and then just build a external fet mod and solder the correct wires to the correect stock fet pinS?
Old 02-11-2004, 05:34 AM
codedat
You can keep them on if you want. But there is the possibility of still buring up the stock fets because current still goes thru them. It's a 50/50 chance it will burn with it or not. Besides it is easier to solder with it off, and remove the aluminum heat sink at the bottom of the car to remove unwanted weight but keep the paper piece to keep most dirt off of the electronics inside.
My Two cents
Feel free to fill the bucket
Old 02-11-2004, 06:25 AM
codedat
Hopefully this should clear things up. Note connecting directly to the batteries is ok but don't forget to connect to the main PCB.
Here is a revised img
If the picture doesn't show click the link here
I belive this is what Neuro said it should be. Note directly connecting the battery is ok but remember that the main PCB needs power also.
I fix the link.
Old 02-17-2004, 12:05 PM
..i dont see any pic and the link isnt workin....
Old 02-17-2004, 04:33 PM
codedat
Try again it will take you to home page then click on the link on the home page
Old 02-18-2004, 08:13 PM
ahhh...ok i see it.....nice choice of colors...its like lookin at a rainbow...
Old 02-18-2004, 11:16 PM
codedat
Thanks
I tried to make it easier for people to see where the connections go.
Old 02-23-2004, 03:48 PM
meteoraclown meteoraclown is offline
i was readin through this and decided to do this when i get some more money. Can someone make a step by step tutorial on this upgrade. I can't seem to find it. If i passed it will they post a link to it and tell what post # it is. thnkx cause i'm new to xmods and only had it for a month(still stock cause i got np money.
Old 02-23-2004, 08:25 PM
....did you check out codedat's pic? his pic pretty much explains everything......just solder each wire depicted in the pic to the places shown and you'll be ok. IC5 and IC6 are the fets on the bottom of the pcb...but all the info you really need can be found in the previous pages....just take sum of your free time and read through the whole thing and you should have more than enough info
Old 02-23-2004, 08:30 PM
ok thanks. i was readin this last night around 10 so i was tired.
Old 02-25-2004, 07:19 AM
neurokinetik's Avatar
Mad Scientist
Just an FYI, IRF4905s are back in stock at Digikey, i got mine Monday.
Old 02-25-2004, 08:01 PM
finally got my fets
hehe...i just got mine...and im gonna be workin on combining the 5v reg and fet mod tonight........finally
Old 02-27-2004, 10:51 PM
charliebrown's Avatar
Originally posted by neurokinetik
Well, I now have the FET circuit hooked up this way. I thought it strange that LithiumXMod said that it didn't work, so I decided to try it myself. It actually does work, and now the only connections that need to go to the main board is the gates of all four MOSFETs. The rest of the connections are on the standalone PCB. Even a Plasma Dash wouldn't kill this setup now. Actually, even a Novak SPY can't handle the current that this setup can.
neurokinetik, TinyRC didn't give you 1/10th the reward you deserved when he made you a mod. THIS IS GREEEATT STUFF!!! I can't wait to get the FETs sooner or later....
Anyways, for some quick Q's: With your FET setup, the amperage limit is pretty high, from what I hear, so I'm thinking of getting the Team Orion Elite Stock 180 motor, and taking about 20-25 winds off the armature. It will have a bit of a high current draw, but I'm guessing the FETs you're using will be able to handle that.
I'm thinking, that with your FET setup, I could possibly run a 15 wind 180 motor, and perhaps that will kick some serious "asphalt" or something like that. I can hardly wait to save enough money to get this little beauty running.....Thanks again!
Chuckster...
Are lipos and FETs worth it? Answer here Jazz32 XMODS Parts and Hop-Ups 24 10-29-2006 08:54 PM
Stock FETs max Amps? 4Runner XMODS 2 05-03-2005 10:53 PM
iWaver PRO FETs Revealed! aaron Mini-Z - Mini-ZRacer.com 0 12-17-2004 08:33 PM
Smoking Xmod!!! 4562 fets? chc XMODS 6 09-21-2004 01:42 PM
