Old 02-11-2003, 09:51 AM
killer's Avatar
killer killer is offline
Proud to be Pinoy :)
:ö: take note that these universal is made from a "rod" and not a tube, you can use a brass / allum. tubes to make part no.1 and 2 and use a allum/ brass "rod " to make part no.3 -æ
hehehe
Old 02-11-2003, 10:30 AM
arch2b's Avatar
arch2b arch2b is offline
TinyRC & Mini-zRacer Fan
KILLER-
what diameter rod are you working with?
Old 02-11-2003, 08:34 PM
killer's Avatar
:ö: Arch,
i'm using a 2mm rod.. i've also attached a drawing to explain how this should look like when used using a larger tube.
hehehe
Old 02-11-2003, 09:28 PM
arch2b's Avatar
killer-
more props to you! i don't think i could work that small. i found very nice drawings of how to make a universal joint, same as yours, on ig mikromodell
Old 02-12-2003, 04:58 PM
killer's Avatar
:ö: arch,
thanks for the additional info!, but i found it easier to build the middle part of the joint by, drilling two holes first on a 2mm rod, then shape/shave it up to the point that it'll fit between the first two parts... there you go again, with your, "i think i can't do that!" line, hey, i thought it was impossible for me too!, but i really want an 8 x 8 all-wheel-drive truck.. then i give it a try.. and it works! it's a bit harder than making the front axle at first, but give it try!, though, i suggest you build your truck first, with a rear wheel drive, this will build your confidence to try building a front drive/steering axle. .. right now i'm in the process of building the second front steering/drive axle to complete my 8 wheel dirve truck project, hope to finish this truck soon!
i'll try to post some pics of my 3 finished axle, including the front axle..
hey, how's your project truck doing?
hehehe
Old 02-12-2003, 07:19 PM
arch2b's Avatar
right now my project is still in the pencil and paper stage of design. i have my brass stock, i should recieve my roco's and faller truck by tuesday, my electronics early next week as well, the batteries and a motor for my overland from the mzr shop by late next week hopefully. so i expect to begin construction late next week.
i'm very excited to see your 8x8 and overlander begin on his tatra.
it looks like tiny will give us our own section on the forum as well i hope everyone will thank him.
Old 02-13-2003, 06:45 AM
killer's Avatar
¤ pics of my 8x8 project ¤
:ö:
hehehe
Old 02-13-2003, 06:46 AM
killer's Avatar
pic 2
hehehe
Old 02-13-2003, 06:47 AM
killer's Avatar
pic3
hehehe
killer's Avatar
front axle
hehehe
Old 02-13-2003, 06:48 AM
killer's Avatar
pic6
hehehe
Old 02-13-2003, 06:49 AM
killer's Avatar
rear
hehehe
Old 02-13-2003, 07:06 AM
killer's Avatar
:ö: hehehe, i know it's 6x6 , as of now, but right now, i'm in the process fo building the 2nd front axle, and add it up to the front, then connect a steering link to make this two axle steer to the same direction.
hehehe
Old 02-13-2003, 08:04 AM
arch2b's Avatar
killer- wow, i'm speechless. very impressive.
any chance you could scan the parts, something to get more clear, close up pictures?
Old 02-13-2003, 09:21 AM
killer's Avatar
:ö:
thanks arch! i'll see what i can do to get a more clear close-up of the parts... i'll see if my friend could bring his digicam next week, and hopefully by then, i'm finished with this thing , i'm so excited to drive this thing around my homemade dirt hills .
hehehe
Losi 1/36 Micro-Desert Truck arch2b Micro-T General 2 11-11-2007 06:18 PM
1/87 scale Truck Rob1962 TTTT 1 11-17-2006 10:56 AM
Im intrested in makeing a 1/87 4WD buggy/stadium truck grimmreap3r TTTT 6 02-09-2006 05:16 AM
selling a 1/87 truck complete fastboy TTTT 45 10-17-2003 09:36 AM
1/87 truck (tttt) Squishy For Sale/Trade 3 02-10-2003 09:18 PM
