12-15-2004, 10:47 PM
Got the CF chassis in the mail today WOOT! Now if the rest of the stuff I ordered shows up soon, I'll be a VERY happy camper indeed.
Zero, you produce a very fine product. I'll be ordering the upgrade kit sometime after the first of the year.
S R
12-15-2004, 10:50 PM
 Thanks!
That receiver is an out of production Hitec Shredder less the case........not too good for 1/10 scale but works fine if distance isn't an issue. Hard to find today..............
12-25-2004, 03:07 PM
hey Zero. For some reason, my CF chassis is causing a number of problems. It doesn't seem to drive straight and the driveshaft/motor seems to bind. Can I get any help?
XMOD Yellow Skyline
AWD
Wide Track Bearings
IC-3
Soft Front, Monoshock
Hard Treaded
NML Stage 10, blue Gear
Carbon Fiber Driveshaft
12-27-2004, 03:12 PM
4WD or 2WD?
Did you shim the rear motor pod with the correct amount of spacers?
Are the front arms and towers aligned?
01-04-2005, 05:04 PM
candyman206
The Hitec Shredder is no longer available, once in a while you see one at auction..............
Some have used XXL receivers without the case but shrink wrapped to save space/weight.
I use the Novak Spy but other micro speed controls can be used. Just beware of clearance issues between your body shell and the chassis. It can take a lot of wiggling and configuring to get it all to fit.
If you use a standard type receiver, wiring is basically plug and play unless you go as far as shortening the leads to keep it all neat.
I use an M8 to control the beast but will probably switch over to the new IWaver 2PL controller I got with their ready set. Any radio will work with the aftermarket receiver as long as they are the same frequency range, 27 mhz is common in this scale.
01-04-2005, 05:20 PM
You got me on that one, in 22 years I've never heard of or used and H-bridge in radio control, unless it is part of an existing component, and I didn't know it was there.
I'll have to differ that to some of the electrical gurus around here.
01-04-2005, 06:50 PM
ICic
No depending on the amp rating of the aftermarket ESC you wont need an H-Bridge
The SPY is built for 1/18 vehicles and can handle most motors in this scale................it is a brushed motor controller though, not made for brushless systems, that is another category altogether........
01-06-2005, 05:40 PM
title? i dont have one!
why arent the chassis's in the store anymore?!
just say no to big sigs
heh.. stolen from viperdout^
01-06-2005, 05:55 PM
SOLD OUT, expect more in 4 or so weeks
01-07-2005, 04:19 PM
dang i was just about to order one lol.. o well i spent the money.. ill be getting one, eventually
01-16-2005, 01:08 AM
Z
Sorry to ask another question. You said that particular receiver is no longer being produced. What would I look for in a replacement to the Hi-Tec shredder, i.e number of channels, AM or FM?
Any opinion of the Hitec HS-50 sub micro servo. Specs show same speed and amp as the HS-55, but seems closer to the orignal Xmod servo in size. Of course it's torque rating is lower than the 55.
Thanks
01-16-2005, 01:38 PM
I have found another receiver!!!
GWS makes a smaller!!! 75mhz FM receiver!!!!!
Just got it in this weekend for use on a Pro-Z mini-Z chassis (Thanx Scott for the info), but it should work even better with the X-Frame.
It is GWS R-4PII/H (4CH Pico Type) and can be purchased in models compatible with Airtronics or Futaba...........
01-18-2005, 02:24 PM
zero is there any way i can get a chassis soon? dont matter if its used.. my email is; jrjamms@comcast.net
msn = back_drift@hotmail.com
aim = backdorifto
01-18-2005, 06:49 PM
Sorry, keep bugging the shop
01-20-2005, 06:09 AM
After doing some research that GWS receiver is 72MHz.
