04-06-2003, 11:24 PM
Wheres the thread...Muscle Machine Wheels...
Wheres the thread that has very in-depth instructions for putting the Muscle Machine wheels/tires onto a Bit? I tried the search, but couldnt find it. Anyone know?
04-07-2003, 09:25 PM
Thank you very much. Your tutorial is the one i was thinking of. VERY nicely done. I'll take some pics when I'm done. Thanks again
04-11-2003, 10:51 AM
I cant stop modding
do you have to do the tires on the ouside of the original rims ?
I dont have a dremal either so what would I do
and do you put the mm front wheels on like normal just drill a hole or is there somthing special
04-11-2003, 12:01 PM
Mr. Goop
nope nothing special... i did realize that the rear wheels are slightly larger. coming from a muscle machine cartoon edititon... anyway. both the front and rear MM wheels are glued to the regular bit wheels. no holes needed to be drilled..
you could use an xacto knife to shave the mm wheel so that the bit wheel fits inside it a bit better, or you could shave the bit wheel so that it fits inside the mm wheel...
you dont have to do either, but by doing so its easier to get a good flat fit on the two wheels so they dont wobble when they spin..
04-11-2003, 01:11 PM
I cant stop modding
i just went out and bought one
I also saw these hot wheels tuner cars which had big wheels they has escalades supras civic and a green car
do they work too
04-11-2003, 01:16 PM
Mr. Goop
i have seen them also. i havent tried one yet. hopefully i will be able to get one soon.. ive spent way to much money making bodys and i am broke... no money left... the next three bodys i got coming are the nomad for the bit, the truck, and im modifying a muscle machine woody to fit a zipzap.. once it fits im gonna do a silicone cast and make some resin bodys... and some wood textred decals for the sides of it.... should look good...i just need to get more silicone... theres the other problem.. im thinking of going to molding rubber, instead of silicone. it is cheaper. for the same price i get twice as much..
04-11-2003, 01:37 PM
Internet Web Ninja
Now are the tires plastic or rubber?.. The look plastic and that mean no traction at all.
I know the super tuners are plastic. I have used pipes and spoilers off of them before.
Thanks,
Jason Webb
- web guy - Dallas, Texas -
04-11-2003, 02:13 PM
Mr. Goop
yea they are a soft plastic... and there is supprisingly enough grip to get going... and they kick ass on carpet. but if all your running on is the kitchen floor, you might want to give them a coat of rubber cement for grippy tires...
