Old 03-30-2003, 04:01 PM
tobenjunk tobenjunk is offline
27,35,45,57 Interference?
I own two MS at 27 and 49 frequency and two Shen qi wei clones at 35 and 45 frequency.
I thought I could drive them all at the same time, but the 35hz SQW controller is able to control the 27hz MS! (just turning slightly)
I was wondering if this is just because the Shenqiwei is controller is made poorly... and if anyone has experienced this problem with actual Bit Char-G cars: e.g. If I buy a 35 and 57 Bit will I be able to drive the 4 MS/Bit at the same time w/o interference? I would find it hard to race if I can sabotage my opponents. :]
Anyhow, I have yet to try the 45hz SQW with my 49hz MS but I am guessing they are so close that there WILL be interference.
I have heard in europe they also use a 40hz frequency?
Has anyone tested this with a 35hz or 49hz Bit? Are they able to drive w/o interference?
Thanks!
Old 03-30-2003, 04:02 PM
Argh! My friend just came back from London for spring break. I should have asked him if he saw any Bits!
Old 03-31-2003, 09:42 AM
SlowbutCourious's Avatar
State Property
..i have ran 27 ,35 ,45 ,49 and 57mhz all at the same time and no interferience..
Old 03-31-2003, 09:51 AM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
Retarded Stunt Driver
same here. sometimes different brands dont like eachother.
microsizers controllers are the crappy ones actually. those round clone controllers get tons better range. clone cars are usually poorer quality than bits but the tomy electronics are horrible.
Old 03-31-2003, 01:34 PM
mc2wheels mc2wheels is offline
Just got my 40 Mhz Compact Char-G
I run all 6 frequencies. I don't get interference with my legit bits (Char-G, Compact Char-G, Microsizer); actually, they do interfere a little if one controller is too close to a different car (~1ft or less), but the 27 Mhz MS drives the 35 Mhz LXX booster, and kills my 57 Mhz LXX booster. I think you have to stay within brands or just get lucky.
Old 03-31-2003, 02:01 PM
hogjowlz's Avatar
yupp
27MHz and 27Mhz channel A do interference??? M_@rt_In Bit Char-G / MicroSizers 0 08-15-2006 02:05 AM
Digi Q and MicroSizers Interference sargent Digi Q 1 12-11-2002 03:23 PM
frequency interference and "stutter" Rex Racer Bit Char-G / MicroSizers 6 11-17-2002 05:01 PM
motor noise interference?? foofinator Bit Char-G / MicroSizers 0 10-27-2002 02:05 PM
fequency interference lookatme ZipZaps 0 10-20-2002 07:23 PM
