Old 02-09-2003, 05:39 PM
trinitron2k2
R-spec, no longer works
I bought an Rspec motor from tinyrc, it worked great for the first two weeks. Now it can't even turn the wheels. Does any one know how to fix this? (its not the car( I tried the motor on both my cars and it does the same thing))
Any help would be apreciated
Old 02-09-2003, 05:58 PM
Namuna's Avatar
Namuna Namuna is offline
Are your gears properly meshed?
To test, put the motor in and hold the car up, then manually spin the rear wheels...Does it spin readily? Or is it an effort?
If it's an effort then the gears aren't properly aligned, keep fiddling with the gears until the rear wheels can spin easily and your motor will work right.
Old 02-09-2003, 10:42 PM
trinitron2k2
no, the gears are fine...when I take the gears off and let the motor run all by itself, it spins very slowly...and hardly makes any noise.....so its not the gears...
Old 02-11-2003, 05:39 PM
trinitron2k2
no one else has any suggestions?
Old 02-11-2003, 06:35 PM
Redfire's Avatar
Redfire Redfire is offline
Just kinda burned you...
Send a message via AIM to Redfire Send a message via Yahoo to Redfire
The same thing happened to me, and my R-Spec.
Try charging it like 4-5x, because it seems to drain MORE out of the battery than usual.
"I won't lose, no matter what, because the prize is a full tank of gas." Takumi
Old 02-12-2003, 12:15 AM
trinitron2k2
charged it 4 times, put the car on the ground, pressed forward, a wild jolt!, and after five inches back to a crawl
I wonder what is wrong with it
Old 02-12-2003, 03:20 PM
Racer9's Avatar
Racer9 Racer9 is offline
Tiny RC Pro
try WD-40! It works like a dream!
Old 02-12-2003, 04:22 PM
trinitron2k2
just tried the wd40...unfortunately it had no effect
Old 02-12-2003, 07:13 PM
trinitron2k2
Just did the double cell mod....OMG....incredible....the rspec was soooooooooooooooooooooooooooooo fast, unbelieveable amount of torque/speed, so I guess its ok now....thanks guys sorry for the trouble
Spec 1 and spec 2 for sale..cheap!! Epochracer34 For Sale/Trade 4 12-09-2003 05:30 AM
motor works batt. Demon666 Bit Char-G / MicroSizers 4 02-25-2003 05:42 PM
FYI:Motor Works (clone) charging base will charge dual and triple battery setups. Clint Bit Char-G / MicroSizers 0 02-17-2003 04:09 PM
Does anybody have any extra Epoch Spec 2 parts???? MicroRCracer Epoch RC1/43 4 09-16-2002 02:28 PM
