Old 01-02-2003, 01:42 PM
fovea3d's Avatar
fovea3d fovea3d is offline
Thumbs up Epoch Track
This is my new track dedicated to Epochs. I had this idea when I found a plywood board the size of a door. It can be stored vertically against a wall and is very light.
Border walls are made of high density styrofoam (polystyrene) roads are covered with matt black spraypaint, "lawn" areas are made of thick green carpet wich makes you slow down to drive to the track again.
The road markings are made with electrical tape.
Once I was used with this narrow track, I could make a lap in 2.9 sec wich is 150mph scale speed with a spec 1 Epoch. Done in one evening, I still need to make barriers so it is impossible to shortcut through the lawn
Old 01-02-2003, 04:49 PM
KAIKS KAIKS is offline
nice looking track
are the dotted lines made from electric tape to?
Old 01-02-2003, 04:54 PM
fovea3d's Avatar
Thank you KAIKS. Yes, a single line was cut in place with a cardboard cutter and one of each two pieces removed then placed on another part of the track. I was surprised how easy and fast it was making it.
Old 01-02-2003, 06:21 PM
irc irc is offline
WOW! That is so cool! What is the length and width of the board and how wide are your lanes? will the cars reach top speed in the strights.
" THINK FAST "
Old 01-02-2003, 06:24 PM
ZipZap "SS"'s Avatar
ZipZap "SS" ZipZap "SS" is offline
SS'mokin!!!!!!!!!!!!!
Send a message via AIM to ZipZap "SS" Send a message via Yahoo to ZipZap "SS"
How's handling...
Is it possible to walk out at all, or do you have good traction? Sweet looking set-up by the way!
Chris
Christopher J. May
Denver, CO
4 ZipZaps (1/64th scale)
Old 01-02-2003, 06:37 PM
fovea3d's Avatar
Its the size of a standard door: 90"x35". The lanes are 10" wide wich represents the width of a small street.
My best car can almost reach top speed. I only have to stop the throttle when entering a curve and give full throttle in the middle of the curve. This track is more of a precision driving challenge and real fun when 3 cars are running the same time: 2 cars can drive side by side, but 3 together won't pass the next curve I also like the way the tires squeal when cornering at full speed
Old 01-02-2003, 06:48 PM
fovea3d's Avatar
Zipzap, you mean to fall down the board or to drive on the carpet parts? I felt once when the car took off hitting the "lawn" at the end of one straight, thanks the Epochs are solid I broke nothing.
The walls are 1" in height so it cannot happen often.
Traction is very very good, sometimes the cars roll over when the inside wheels are on the green, but the matt paint also eats the tires pretty fast.
Old 01-02-2003, 07:11 PM
fovea3d's Avatar
DSL only: videos!!!
Check this out if you want to see a lap.
The videos are not so good especially the second one.
I had to stick a webcam on a baseball cap so its a driver point of view
http://www.fovea3d.dynu.com/public/E...0Oval%2002.AVI
http://www.fovea3d.dynu.com/public/E...0Oval%2005.AVI
Make sure you have the DIVX codecs
Spud, LiPo Powered 25K Turbo Epoch LBRC Epoch RC1/43 3 03-29-2005 04:12 PM
My New track and a pic of my work area zydio ZipZaps Gallery 15 01-12-2005 05:17 PM
Track idea, comments wanted MoobY Tracks 3 12-07-2004 10:01 PM
Porta-Trax announces SuperCircuits Pro Track Kits lornecherry Bit Char-G / MicroSizers 18 04-02-2004 01:34 PM
Track layout idea Talon Bit Char-G Mods and Projects 0 12-31-2002 03:39 PM
