Old 12-25-2002, 10:28 PM
95_civic_coupe 95_civic_coupe is offline
is it possible....
to put in a 150mh battery to replace the 100mhz battery?
and will i be able to use a 3.8 motor in w/ the 150mhz battery?
Old 12-25-2002, 10:48 PM
ZIZI's Avatar
ZIZI ZIZI is offline
no unless you do the PCB transfer...
but you will get a bit longer runtimes...
ZZ RX-7
No reverse mod, PCB mod
NOS Motor
3.8 (in the mail)
Old 12-25-2002, 10:51 PM
wut battery can i put in there to handle the 3.8 motor, without haveing to do the dual battery mod?
btw for the no reverse mod is the yellow wire the on in the center of the side where the motor is?
Old 12-26-2002, 10:52 AM
ZIZI's Avatar
I dont think there is any...
The only way to use the 3.8 is a PCB swap...even with a double battery mod you might not be able to run the 3.8...as for th eno reverse mod I am not sure wat you are asking but here is a diagram of how to do the mod with an extra switch in it...which helps alot...(you can switch)
ZZ RX-7
NOS Motor
3.8 (in the mail)
Old 12-26-2002, 12:34 PM
can u please label all the parts like the wires and stuff? i would appreciatie that. thanx
Old 12-26-2002, 01:11 PM
ZIZI's Avatar
Umm...ok..crap it didnt save...
ZZ RX-7
NOS Motor
3.8 (in the mail)
Old 12-26-2002, 05:08 PM
is that black thing on top the battery? and what kind of wires do i need to use?
Old 12-26-2002, 05:18 PM
ZIZI's Avatar
yeah that is the battery...you know what will tell you the whole procedure:
1: You see the yellow wire gooing from the motor(the metal thing connected to the motor) cut it in half.
2.get a switch with 3 of those solder tabs on the bottom...I will call them tab1, tab 2 and tab 3
3. the piece of wire that is going to the motor (yellow wire) solder to the center tab. or tab2
4. the yellow wire coming from the PCB solder onto tab 1.
5. now get a small wire preferably same gauge as the prvious wire and solder it to the + of the battery (i soldered it to the metal tab for the battery) and the other side to tab 3.
6. Now there it is the no reverse mod..with the ability to change back to normal with the flip of a switch.
Easier mod but cannot switch:
1. Cuy yellow wire by the PCB and connect it to the battery terminal.
If you cannot do it after this explanation then perhaps this mod isnt for you...
ZZ RX-7
NOS Motor
3.8 (in the mail)
Old 12-26-2002, 07:59 PM
the long one that sticks out from the car?
Old 12-27-2002, 10:10 AM
ZIZI's Avatar
Uhhh..no
you have to actually open up your car and read m instructions carefully...
ZZ RX-7
NOS Motor
3.8 (in the mail)
Old 12-27-2002, 10:25 AM
go_zz_go's Avatar
go_zz_go go_zz_go is offline
more power!!
not trying to be rude but i wouldnt try it if i were you,,,it dosent look like you understand it fully,,,i might try to put some pics up,,but i am not sure when i can,,,amybe soon
Old 12-27-2002, 02:16 PM
Re: Uhhh..no
i did open it up
1995 black civic coupe ZZ
Old 12-27-2002, 02:19 PM
oooooooooooooohhhhhhh i get it now, when i get a switch and some wires i will try it. thanx
Old 12-27-2002, 04:53 PM
wild03 wild03 is offline
Just want to remind everyone that it is possible to TRY the 3.8 without modding the board, For those of you who want to see how the motor performs. you can build a simple transistor switch circuit to power the 3.8, this was the original purpose of the circuit but I haven't been able to get my hands on a 3.8 yet.
Check the bit science forum for "4.5 volt dragster" You don't have to use 4.5v just add a second battery just to power the 3.8
Old 12-27-2002, 11:44 PM
jutte07 jutte07 is offline
Send a message via AIM to jutte07
q
if i were to do the dual batt mod, whould i b able to use the 3.2 motor, b/c i no i cant use the 3.8 w/out the pcb swap, and i dont even no what a pcb is skip that. and if not, can i do the dual batt with a 150mhz battery and use the 3.2 or the 3.8???
