Old 07-26-2002, 09:34 AM
dvious1 dvious1 is offline
Update on my bit
here it is with the 17" TSW's from the Modifier car.
i manage to get the from whells on, but im still working on the rear wheels. right now its more show than go.
ne1 know how to separate the gear (without breaking it) from the rear axle?
Old 07-26-2002, 09:35 AM
here's another
Old 07-26-2002, 11:07 AM
tinyrc's Avatar
tinyrc tinyrc is offline
Wow, very cool! Do you know if you can buy the wheels etc. separately or do you have to buy a whole car?
Old 07-26-2002, 11:35 AM
Neon_Skylineboy's Avatar
Neon_Skylineboy Neon_Skylineboy is offline
Send a message via AIM to Neon_Skylineboy Send a message via Yahoo to Neon_Skylineboy
Do the tires come off on those wheels??
Old 07-26-2002, 11:38 AM
tinyrc, i emailed the company regarding whether they will sell or offer accessories separately for future upgarades to the modifier cars, and they said "not at this time".
the modifier cars are cool, but once youve played with it a few times it get boring. i have the 99 civic si and ive taken it apart several times. now i just use it for spare parts for my BCG.
Old 07-28-2002, 12:12 PM
Neon, the tires do come off the rims but u cannot fit them on to the bit's rims.
Old 07-28-2002, 01:30 PM
damn! thanks for the answer though...
Old 07-30-2002, 04:30 PM
LitBmx LitBmx is offline
Send a message via AIM to LitBmx
hey do the antina thru hood mod ;)
oh btw beautiful BC-G got a lancer evo but its red so ill proly paint mine like urs with 2 racein stripes
Old 08-03-2002, 08:39 PM
kbtoyz902's Avatar
Bit OG
Howd you put the wheels on your BC, i have my integra wheels but have no idea how you did that. You can post here, or aim me at kbtoyz902 if you like.
Old 08-04-2002, 12:52 PM
kbtoyz902, the front wheels were easy.
1. disassemble the bits front wheels (remove the rims, u need a mallet and a small nail).
2. take the rims and unscrew the hubs of the modifier car.
3. then screw the hub from the modifier car directly into the the white plastic piece (suspention and wheels holder) of the bit.
thats the front, the rear is a mess. right now i havent been able to get the gear off of the rear axle of the bit without damaging it, so it more show than go.
to get the rear on, just take the rims and the hub from the modifier. you would need to create an axle (i used a long nail, same size as the bits axle). once u do that, just insert it through the hubs.
hop this helps. let me know if u need more info.
Old 08-04-2002, 07:07 PM
kbtoyz902's Avatar
Bit OG
that helped a whole lot. Just curious, what do you use to hold down the rims while u take it off the white thing?
Old 08-05-2002, 09:44 AM
i drilled a tiny hole (same size as the pin that holds the rim) onto a board 1/2 inch deep. i just lined up the hole with the pin and carefully used the mallet and the nail to poke the pin out (the pin would just drop into the hole).
Old 08-31-2002, 10:17 PM
Redfire's Avatar
Redfire Redfire is offline
Just kinda burned you...
Send a message via AIM to Redfire Send a message via Yahoo to Redfire
wow. Are those [rubber] tires? and can the front wheels turn left and right at least?
"I won't lose, no matter what, because the prize is a full tank of gas." Takumi
Old 09-01-2002, 01:07 PM
Redfire
yes, they are rubber tires.
yes, u can turn the wheels only if the car is not lowered. once u lower the bit, u have 2 trim the wheel well.
Old 09-01-2002, 11:44 PM
Redfire's Avatar
thats really great man. good job!! keep up the good work! ima do the same to my bit heh
Bit Online Update 1llusI0n Bit Char-G / MicroSizers 0 12-04-2002 09:51 PM
