11-22-2002, 11:44 PM
Toy Collector
Booster & 4-Band Experience
Booster Car & 4-Band TX Experience
A lot of people are asking what The 2 speed Booster Cars are and how dose it work.
Booster Cars (also known as 2 speed) are available as a kit called the "booster kits" @27,35,45.&57mhz and currently (11/22/2002) the "Nissan 350z"@57mhz and the "Automodellista Set"@27mhz. If you Already Have a Bit car and want to upgrade, you can get the "booster kits" which includes: 2 Speed Chassis, 2.2 motor, 9.86:1 gear axle, Medium tires, and a clear Skyline Body.
These sets do not come with the controller. You have to get TOMY's 4-band controller. The regular controllers will not work with the booster chassis unless it's the one that came with the Nissan 350z and Automodellista.
The 4-band controller has a function button on the top-right that activates the second speed. This is not NOS or Turbo and has nothing to do with it and has nothing to do with Zipzaps NOS/ Turbo motor either  .
From my experience with the booster chassis is that on my 2.2 motor, if I don't have the button pressed, it runs a little bit faster than a 1.0 motor but with less torque (perhaps 1.2 or something . . . just guessing). I compared it by using a 1.0 on my NSX and a 2.2 on the Automodellista (same grearing). But when the button is pressed, it runs more like a 2.6 (although my 2.6 runs slower, I think I have a crappy 2.6. I will test again when I get a new 2.6). It's definitely Faster tha a 2.2 on a non booster car ( I compared it to my AE86 Trueno with a 2.2 & same gear)
About the 4-band controller: There is a switch in the back that has 3 settings.
B = booster chassis compatible ( 1st speed and when function button is pressed, 2nd speed)
C = always in 2nd speed mode
A= compatible with single speed (non-booster) chassis
I have read in some posts that It dose not work with older cars that don¡¦t have a "4-Band" sticker in the box. The oldest car I have is the AE86 Sprinter Trueno (G-09) and it "dose not" have a 4-band sticker on the box. But I tested that it works just fine with the AE86 with the 4-band controller in MODE C. (It even works fine with my OEM LXX chassis @27mhz). Other Models older than that (G-01 to G-08) I have not tested.
I hope this helps some of the questions I see.
If there is a mistake let me know
NSX-R , FairladyZ33, Auto Modellista, AE86 Trueno,
Calsonic R34, R34(WHT), Evo VII(YLW)
11-23-2002, 02:42 AM
Runs with sharp stuff
The boost controller definitely does not work on the blue Skyline. I tried using it with no luck with the switch in either of those positions.
11-23-2002, 04:06 AM
Toy Collector
I'm not sure if they ever revised the circuit boards later in the manufacturing. The G-03 Blue Skyline is one of the first ones. If that is the case then I'm assuming G-01 to G-04 dose not work ...unless they revised the boards.
And also since it's compatible with my G-09, i'm assuming it will work with kits made after that. ( correct me if that is not the case)
How about the rx-7's and the Celica's? Anyone?
11-23-2002, 09:38 PM
I have a newer S2000 with a silver body, and there is a sticker on the box that says that it's 4-ch capable. They did make a production run change to accomodate the new controllers. That is probably the reason why the older bits disappeared for awhile.
11-30-2002, 09:41 AM
Can somebody please make the differentiation between 4 band, and 4 channel for me?
Which one is it?
If it's a 4 band controller, then it lets you control cars that are 27, 35, 49, and 57 mhz.
If it's a 4 channel controller, then it lets you have the foward/back, left/right, and 1st/2nd speed, and one other channel.
I'm just a bit confused.
-Scott
MicroSizers:
Red Lancer (27)
Yellow bB Open Deck (49)
Blue Skyline (27) :: Clone Motor (2.?)
Yellow RX-7 (49)
Black Celica (27)
White Impreza (49)
11-30-2002, 02:06 PM
Sorry for the confusion. The controllers are all 2-ch. Except for the boost controllers where you can technically call it a 3 channel. When you can select the frequencies, you can call them 4-band.
I'm out like the fat kid in dodgeball.
11-30-2002, 03:08 PM
Who sells one of these 4 band controllers that has one IN STOCK , right now that takes paypal?
-Scott
MicroSizers:
Red Lancer (27)
Yellow RX-7 (49)
Black Celica (27)
White Impreza (49)
11-30-2002, 03:58 PM
Hachi Roku
Blue bit ur the man. great info about the 4 ch. it is only compatible with cars that have the little 4 ch logo in the top left corner i have it and it works great i also have 2 boosted cars that rock
"East Coast to West Coast on 1 grain of rice"
11-30-2002, 04:20 PM
Toy Collector
thanks  RacerXero
ScottM http://www.jdmtoys.com and http://www.tisinc99.com/ claim tht they take paypal and have them in stock but I have "never" ordered from them before.
11-30-2002, 06:01 PM
Char-G
I have a G-03 (skyline) which has the rev 5 pcb, does anyone know if the 4-band controller will work with it? The box doesn't have any 4-band logo on but my G-05 does.
For we are many!
11-30-2002, 06:29 PM
Toy Collector
As I mentioned my oldest BIT is the G-09 Trueno @27mhz. The Revision number under the chassis PCB is REV4 and on the stock controller is REV3. My Box dose not have a 4-band logo. I am not sure about the G-03, but it did not work on the one alpha1 tested. My white skyline is a Microsizer@49mhz and not a G-04 Bit.
11-30-2002, 10:19 PM
www.tinyrctoys.com has the controller in stock, and accepts paypal.
12-08-2002, 11:13 AM
cool i just ordered a  350z from toyeast on the 5th cant wait!
My Fairlady Z:
 *rare earth*
01-04-2003, 03:08 PM
That's all folks
Hey Steve-o, you running two batteries with a booster car? Any problems, does it work good?
That's all folks!
02-17-2003, 04:22 PM
NEWBIE ALERT!!!
AHHHH CRAP
you guys have totaly confused me; heres the deal:
i've ordered the Bit Char-g Automodelista Set
Gear Set (GS-03)
3.8 motor
Reinforced Heatsink
160Ah battery(i think)
Tire Set (S0-2)
NSX
(all due to arrive in a couple days time)
first off, can you please give me any info/tips/probs with what i've ordered and secondly, what this i'm hearing oh the AM set being a booster set or 2 speed set? how will this effect me changing the motor, what precautions do i need to take etc etc
*nervous breakdown*
please please please is there anyone outhere who can help??
Thankksss
