Old 12-26-2006, 01:18 PM
Namuna's Avatar
Namuna Namuna is offline
The Compatible Parts List
Alright folks let's use this thread to track all the compatible parts and pieces we've found that fits the Micro-T. I'll keep this first post updated as new info comes in. Let's start:
Motors
Feigao LPS 5250 brushless motor - 12x22mm 5250kv (Part #1208430S)
Servos
Hitech HS-55 Servo.
Towerpro SG90
ESC
Castle Creations PHX-10 brushless ESC
Castle Creations Mamba 25 Brushless ESC
Novak Spy
Receivers
Spektrum SR3500 Micro
Transmitters
Any 27MHz AM band Tx should work.
Chassis Upgrades
eXo-T Lexan Chassis upgrade: http://www.ripper7racing.com/r7rforu...read.php?t=788
Jrx-Z CF Chassis upgrade: http://www.pro-z.com/jrxz/
E-Clips!...Arrrgh!
- Launched an e-clip into neverland? Try using a staple! LOOK
- Also noted is that the e-clips are the same as the ones used by the Mini-T (Losi Part#LOSB1043. Usually sell for $1.50 in packs of 10!).
Alloy Parts
GPM: http://gpmracing.com.hk/car/page/pop_tm01.asp
Hot Racing: http://www.hot-racing.com/index.cgi?c=234
RC Atomic: http://www.rcatomic.com/main/modules...hp?storyid=226
TheToyz: http://thetoyz.com/cart/thetoyz_cate...0T&action=list
Bodies
Parma: http://www.parmapse.com/Images/aahom...60100_Sell.jpg
BRP: http://brpracing.com/18minit.html
Batteries: Note: Stock batteries are 32.3mm x 20.8mm x 11.7mm
NiMH Batteries:
- Kan 4.8v @ 160maH packs at Cheapbatterypacks.com
http://www.indoorflyer.co.uk/index.a...&productid=186
- GP Batteries: Part:GP16AAAM (1/3AAA size) 1.2v @ 160mah NiMH cells (10.2mm x 14.6mm). Build your own packs (x4)
- GP Batteries: Part:GP11AAAM (1/4AAA size) 1.2v @ 120mah NiMH cells (10.2mm x 10.7mm). Potentially build your own 7.2v 120mah battery.
LiPo Batteries (listed are only Lipos that will fit without any chassis mods):
- Team Losi 7.4v @ 180mah Lipo w/charger Team Losi
- Aero-nuts 180mah 15C Lipo @ Aero-Nuts
- HXT 200mAh 12-20C Lipo @ UnitedHobbies
- Full River 250mah 10c Lipo @ IndoorFlyer (UK Based).
- Micron FP 250mah 12C Lipo (3.7v Cell Part#:m082, 7.4v Pack Part#:m800). This is unconfirmed, but supposedly these batteries will fit the stock battery compartment with only a little finagling. There's also the Micron 230mah 15C Lipo (Part#:m083).
Stock Battery Connectors:
http://www.molex.com/cgi-bin/bv/mol...ucts&Lang=en-US
Part Number: 51006-0200 (Female)
Part Number: 51005-0200 (Male)
Wheels/Tires
Micro RS4 or Xray M18 Rear wheels are a direct slip-on over the wheels/tires of the Micro-T! Check out this picture of a set of RS4 Foams on a Micro-T (not mine):
http://rcbros.com/pop_up_image.asp?s...head/CF7_1.jpg
Misc.
- The suspension springs from an XMods Evo has been reported to work on the Micro-T
...Keep an eye out on this original post as I will be updating it as I find new info and as anyone post info here.
thanks.
Credit
Credit for the information above goes to; crazydave, TheSteve, betty.k and others from bitpimps, yourmicro.com, one18th.com, Ripper7Racing.com, RCGroups and other forums. If I've missed anyone deserving of credit here, please let me know.
Old 12-28-2006, 02:40 PM
Namuna's Avatar
Adding the following items to the list:
And making some changes to the layout of the original post.
Old 12-28-2006, 09:50 PM
SCARHARDT SCARHARDT is offline
Exclamation Batteries
Gold Peak 4.8v 160mah NiMh battery pack $11.49
HERE
Old 12-29-2006, 02:26 PM
Namuna's Avatar
Higher capacity pack, for slightly less than stock. Nice!
Killer Hobbies is also solid shop. Nice find SCARHARDT. Hope you don't mind I updated your post with more detailed info.
Old 12-30-2006, 09:59 PM
no probs
it is a good find, ive been searching everywhere lol, gf is getting a little peved that im spending too much time on this little machine
and thanks!
Old 12-30-2006, 10:05 PM
Namuna's Avatar
Added a quick tip about using staples in place of lost eclips.
Also added about the Micro-T using the same e-clips as the Mini-T.
Old 12-31-2006, 02:17 PM
Slicks
im gonna try and grind down my old set of rubber for slicks, im running on a linoleum floor, so im gonna use some tricks from my slot car days, will post pics asap
Old 01-02-2007, 12:15 AM
Keono Keono is offline
I took some destroyed tires from my Micro-T (it's easy to destroy them on a tight thread carpet) and removed all teh rubber. I then put Foam Tape from Home Depot on the tires and now I have foam tires. so, stock tires+fun+ Home Depot=Foam tires for hardwood floors
Old 01-02-2007, 12:42 AM
HERE
I'm sorry my friend, you got RIPPED OFF.
http://www.cheapbatterypacks.com/mai...er=3&model=419
You can get the 160 MaH 4.8V yadda yadda yadda, for roughly 8 bucks on cheap battery packs.com
Old 01-02-2007, 08:26 AM
Namuna's Avatar
Sounds great! What's the part/ticket# of that Foam Tape at Home Depot? And/Or do you have pictures?
Good find on the Kan batts at CBP. CBP also has a good reputation.
Thanks.
Old 01-02-2007, 08:52 PM
hmmm I thought I got it from home depot... It's single adhesive sided foam. I went to home-depot.com and couldn't find it at all... I tried a couple crafts sites as well... I'll keep looking, and if I find it, I'll link it. sry... I bought the stuff a LONG time ago.
Old 01-03-2007, 12:33 AM
LBRC's Avatar
LBRC LBRC is offline
Only problem is that the Cheapbatterypacks.com doesn’t have Micro-T battery connectors, where as the ones from his post do. On the other hand why not get them directly from OnlyBatteryPacks.com instead of resold by Killer hobbies probably with a markup.
Old 01-06-2007, 10:56 AM
3 bucks?
i dont consider that a rip off, especially when it might cost 3 bucks for a connector
Old 01-07-2007, 11:38 PM
sry, I didn't mean to offend. I thought it was a ripoff becuase I auto convert EVERYTHING to deans/micro deans clips right off the bat, and I'm pretty sure CBP does micro deans. as for the foam, I found some in walmart. it's not a tape, it's a sheet. thin, but cheap. $0.89 per sheet. one side is adhesive. I don't know where I got that other stuff. I can't find it anywhere, and I'm all out of it...
I thought of something to make some big foamies for the micro T as well. I'm gonna do it myself as soon as I wear out another set of tires.
http://www.rchobbiesandmore.com/prod...0&cat=0&page=4
Cut these into the right width.
glue/double sided tape the tire, and voila, you got foamies.
Old 01-08-2007, 11:05 PM
Namuna's Avatar
Just added "Wheels/Tires" info, the RS4/M18 Rear wheels are a direct slip-on! Sweet!
Stock parts list required to convert a Micro-T to a Micro-Desert Truck arch2b Micro-T Parts and Hop-Ups 0 11-12-2007 08:55 AM
What mini-z parts are compatible with the x-mod? mustang_steve XMODS Parts and Hop-Ups 9 01-18-2004 06:56 PM
List of parts wasuri XMODS Parts and Hop-Ups 1 10-27-2003 09:30 PM
Are Bit Char G parts compatible with Micro mites?? SPEED Bit Char-G / MicroSizers 2 08-20-2002 05:31 PM
