  #16
Old 12-30-2005, 11:05 AM
rc+bass rc+bass is offline
Okay, I'm new to all the whole micro rc biz and I would appreciate if someone would please clarify which motor I would need to use if I wanted to upgrade my zz mt's steering... I'm reading this thread and I’m getting more and more confused because it sounds like some people are using zz motors and others are using microsizer motors. Which is it? Because, when I popped my pcb cover off last night, I discovered that the motor is smaller in diameter then the usual zz se motors. Thus, the zz se motors would not fit into the steering motor housing. So, what kind of motor would I need to make this work without compromising the battery life too much when I add the stronger steering motor? Microszer motors? Which color?
Thanks
Old 12-30-2005, 03:38 PM
Falcon15 Falcon15 is offline
You need to use a regular zip zap motor, not SE. It'll fit fine, just make sure it's a regular zz motor. Note that the more powerful your steering motor is, the less battery life you will have.
Old 12-31-2005, 05:19 PM
GerG GerG is offline
OK, you dont know a friggin thing about what your talking about zipzaps and zipzap ses take the SAME EXACT motors.
Old 12-31-2005, 08:49 PM
Originally posted by landmine22
no there not the se are propo steering the zipzaps are just one step
Umm no that makes two of you..the motor you use is the motor that DRIVES the car and the zz dosnt have a motor to steer it has magnets and the zz se has a servo for steering which yes it does have a motor but its way different. You use the DRIVE motor the one that drives the car. Is it that hard to read the thread and see what motor to use??
Old 12-31-2005, 09:12 PM
ok, he said that his SE motor wouldn't fit. I've never seen an SE motor, so I assumed it must be different than the regular zip zap motor. If it's the same, then I'm not sure why he's having a problem.
Old 01-01-2006, 08:31 AM
Well dont assume when your helping people if you help someone make sure you are right about what your saying.
Old 01-03-2006, 09:45 AM
Okay, I'm getting even more confused now... I can say this for sure, the zz and zz se drive motors are the same size; I finally saw one the other day. Plus, I got my hands on a Microsizer motor too and confirmed that it WILL fit. So unless there are even older zz versions that use smaller drive motors, I don't think they will fit in the zz mt steering motor housing.
Old 01-03-2006, 02:44 PM
They NEVER changed the size of the motor or else there would be more types of zzs than zz and zzse.
Old 01-03-2006, 07:04 PM
ok i forget the monster has the one step moter yeah i'm sorry about that
There is no "one step motor" its the pc board that varies the volts going to the motor for variable speed.
Greg
Old 01-04-2006, 12:28 PM
4AAAbatteries 4AAAbatteries is offline
the diameter of the ZZ motors and the MT steering motor is the same. the difference is that the ZZ motor is longer. i tried it and it worked fine but i decided to gut an SE and transfer everyting to my MT instead.
Old 01-13-2006, 07:26 PM
Warrior Warrior is offline
is the stock steering motor better for off roading or the zipzaps motor
thanks
Old 02-02-2006, 08:10 PM
maxx4life maxx4life is offline
ok, it looks like some people here are confused so here is a pic of what i did.
i used a RED ZIP ZAP MOTOR. just solder leads onto it and put it in. you will either have to drill a hole or cut the pcb cover so the motor will fit because the motor is longer. Don't forget to change the pinnion gears too, make sure you put the pinnion gear that is on the stock motor onto the new motor.
colin
Old 02-03-2006, 11:23 AM
what kind of soldering tool do you use and how much watts is it. the one i have is good for nothing and looking into buying a new one.
thanks
Old 02-03-2006, 06:04 PM
i use a regular soldering iron, it's 23W. i got it from the local hardware store for like 13$.
colin
make sure you use flux
Old 02-03-2006, 06:23 PM
thanks i go look at my hardware shop soon so i can get back to dain my mods. does it matter what kind of flux it is?
Stearing Problems flamehead_16 XMODS 0 07-03-2006 07:24 PM
any1 no how to make ur Xmod Stearing Better if you do post it here whitenight XMODS Mods and Projects 3 11-28-2004 09:37 PM
Drop the Slop... Stearing that is Cyfiawnder XMODS Parts and Hop-Ups 11 01-07-2004 02:43 PM
locked stearing Comrade_Boris ZipZaps SE 2 11-05-2003 05:18 PM
Wild-G has Stearing weels ? e_lm_70 Wild Char-G 6 01-15-2003 02:12 PM
