Old 12-25-2005, 07:32 PM
crazyone crazyone is offline
how do u make an xmod h2 a rock crawler
hay i got a xmod evolution h2 hummer for x-mas and was woundering how i can make it a rock crawler and what i would need thanks.
crazyone
Old 12-28-2005, 12:35 AM
mecheng.wannabe mecheng.wannabe is offline
Hi Crazyone
I don't own an evo yet but I think locking the diffs some how maybe put some gum in them or something else soft so you can always clean it out later I f you change your mind on crawling. and
soft tires semi neumatic that means they have air in them but can be squeezed out.
Old 12-29-2005, 01:59 PM
the Diffs are very hard to lock in the evo truck as they are almost permintly held together with a pin. you might be able to get it apart but you risk breaking or weakining it. your best bet would be candel wax melted into it, you might be able to heat it up and get it out later, or maybe buy a couple extras at atomic mods and lock them with hotglue or something like that. also for rock crawling you want to get the stage 2 motor kit and use the lowest (8-25) gearing and probibly the stage one motor (more torque than stage 2) a mild body lift if you can manage that would help, I did mine using the stock plastic bushings that I had replaced with bearings. now with the stock tires on my rear can fully articulate without rubbing on the wheel wells.
Nissan Skyline GTR v-spec
AWD
more to come...
Make your own composite sheets. bizzybody Bit Char-G Mods and Projects 0 04-05-2007 05:15 AM
1/24 Rock Crawler bluemonster TTTT 4 01-07-2005 11:27 PM
Almost fully modded Xmod for sale TeaQue For Sale/Trade 2 07-18-2004 10:01 PM
Can you make an XMOD FWD?? (FRONT WHEEL DRIVE) jamiekulhanek XMODS 3 06-04-2004 12:24 PM
my ( kind of still a mini-x) rock crawler lowam Mini-X Parts and Hop-Ups 16 12-26-2003 03:04 PM
