Old 10-15-2005, 10:24 PM
vdubin vdubin is offline
problem with evo steering
I have found a problem with the new evo chassis. If you like to run your car on carpet you will get hung up. The steering arms step down away from the lowest seat on the control arm. This step down makes the connecting screw longer than it needs to be and it snags on even really low cut carpet.
I hope this gets corrected by someone in the aftermarket. I tried changing screws and it's no use, the old xmod screws are all too large in dia. and the step on the original screw prevents tightening it more.
Old 10-15-2005, 10:28 PM
KingFuzz's Avatar
KingFuzz KingFuzz is offline
No title
I'm guessing you are running one of the cars. I noticed that screw on my F-150 but it has been a problem since the tires are bigger. I'll have to keep that in mind when I pick up the Mustang.
Old 10-15-2005, 11:53 PM
gnubee gnubee is offline
http://www.one18th.com/GetGallery7723.htm
third pic is my fix. shorter screw collared with insulator from stripped wire. the stock screw is too long. i also suggest the suspension lift kit.
Steering problem rody XMODS 1 01-29-2007 10:18 AM
Really Bad Steering Problem, unlike any steering problem before it! 'Vette Nerd ZipZaps SE 11 07-19-2006 10:05 AM
Steering problem Vincent Bit Char-G / MicroSizers 3 11-25-2002 12:11 AM
AH-HA!!! Solved uneven steering problem! mechanist ZipZaps 8 10-17-2002 09:24 PM
