  #46
Old 08-14-2003, 10:46 PM
FoeverClownin's Avatar
FoeverClownin FoeverClownin is offline
Send a message via AIM to FoeverClownin
HAS ANY ONE USED THE FRONT KNUCKLES AND REAR AXLE OF A BIT 2 HAVE A FULL SIZE WHELL MOD. AND ALSO I READ HOW DO DO SPINERS ON ZZ RIMS BECAUSE THE ARE HUBCAPS
Old 08-16-2003, 02:20 AM
Got 4.2 King? I do : )
the panther is the same chassie as the bit and the bodys fit fine
MY XMOD!
Yellow skyline
Springs: Hard all around
1.5 degree toe in
hard slicks
Top Speed stage 2 motor
full bearings
AWD
6 spoke wheel upgrade
energizer rechargeables
6 Cell Upgrade
Old 01-04-2004, 09:50 PM
wekilledbambi03 wekilledbambi03 is offline
45k motor
does anyone know if this motor really works in a zz? the guy says it was tested but i was wondering if any of u tried it.
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=3168071304
Old 06-14-2005, 02:26 AM
wedge wedge is offline
Car-100 compatibility list
If anyone needs to know about Car-100 compatibility here goes.
Compatibility was tested with components from bitcharg, shen qi wei and a variety of clones.
Motors: YES.
Took all test engines with a slight mod: one of the terminals in the engine bay needed prizing in a little, since the Car-100 motor has extra length from a huge base terminal. Once this was done, the engine bay was fully compatible with all test engines
Suspension: YES, but the mounting holes on the car-100 needed drilling out slightly. Once done, Car-100 could use all test suspension bars.
Rear axels, front wheels, tyres: YES
Gears, steering components: YES.
Batteries: NO. The Car-100 SUCKS power, it uses a 160mAh batt. I haven't actually tried the 50 or 80mAh hour batteries in the Car-100 yet. I expect they might not even power the board, and if they do work will have woeful running time.
Heat Sink: NO.
Shell: Not a hope in hell (Car-100 chasis too long).
Picture shows 4.2 clone engine in Car-100 engine bay. Note angle of terminal - it has been bent forward since the clone motor is too short.
Stock parts list required to convert a Micro-T to a Micro-Desert Truck arch2b Micro-T Parts and Hop-Ups 0 11-12-2007 09:55 AM
Making a "complete" list of all small R/C... Please help! Drake Auldey (All) 0 07-01-2006 07:15 AM
Mini-X Model Body Compatibility List tinyrc Mini-X Parts and Hop-Ups 12 03-15-2004 07:09 PM
list zip zap drag times and mph ml22 ZipZaps 12 02-28-2003 11:21 PM
Crip Cap Master List aero Bit Char-G / MicroSizers 3 12-07-2002 10:47 AM
