04-04-2005, 02:06 PM
who here......
who here really runs the sh** out of there truck i mean actually runs in dirt oh yeah will this hurt it and my truck holds low charge should i replace the transmitter batteries
04-04-2005, 04:22 PM
Tiny RC Pro
i do! i do!
I even made a track for them, lol
Yeah you should replace the batts.
04-04-2005, 04:47 PM
zipped up tight!
who's gonna be the first to seal their tires and see if it floats?
04-15-2005, 04:35 PM
i think i shall try this sealing idea. this could get intereesting or very bad and ruin my truck. but that is a risk im willing to take. muhaaaaa
04-15-2005, 08:19 PM
well the a seal aprantly didnt work because now my trucks submereged in water. when i left is was floating but oh well, i guess i use more goop.
04-16-2005, 09:24 AM
zipped up tight!
I have to know...do they run under water?
04-16-2005, 10:59 AM
kinda sorta. if you can figure a way to keep the board dry than it will run till it stops or needs charged. the tires float but it wont hold the truck up so i had to come up wit sompin but i guess it didnt work. ill try again later.
04-16-2005, 04:39 PM
Tool User
Where on the chassis is the water line until it goes under?
Have you tried progressively gutting it to see how light it'd have to be to float?
DId you put *whatever sealing agent* also around the battery contacts, switch, steering adjuster, screws, lower plate to tub mating surface...
Oh yeah, and um, how about some pics?
04-16-2005, 07:20 PM
ok calm down turbo it goes till bout the top of the chassis before your board gets wet then you have to puul it out its fine. i didnt seeal anything but the tires and ill try to get some pics on when i figure out how to make them smaller
