Old 12-20-2004, 11:06 AM
JesterDotcom JesterDotcom is offline
3D Racer
I think I noticed something
Has anyone else noticed a resistor that is directly in the path of the negative terminal's conection. If I were to remove it would more power go to the board?
If it ain't broke make it better
Old 12-20-2004, 11:26 AM
Skurge420's Avatar
Skurge420 Skurge420 is offline
Gerbil Racing
Send a message via AIM to Skurge420
looks like it but that might let too much power go to the board and fry it
Mini Cooper Mini-Z
AE86 Corolla GT-S Micro RS4
Old 12-20-2004, 11:54 AM
skyline_69's Avatar
skyline_69 skyline_69 is offline
SkyineRC Pro
Send a message via AIM to skyline_69
you would have to desolder the resistor from the board(leave it connected to the battery wire)...then you would have to use a multimeter (like this )
and test the voltage and amps coming through the resistor, then desolder the resistor completely and test the volts and amps again but without the resistor.....i think these board can only take 8.4 volts max(without FETs)...so if you've got more than that without the resistor then you should leave it in there
-1999 Nissan Skyline GT-R 34
-Paint in the works
-Airbrushed Wheels(stock)
-Mesh Front Grill
-Stage 2 SB Hybrid Drift Motor (8 tooth)
-AWD
-CL Lights
-CL Underglow
-6 CELL BABY!
Old 12-20-2004, 08:10 PM
Phred168 Phred168 is offline
I think it's a 5.1v zener diode.
1997 Red Toyota Supra (It finally bloody runs!)
Mods:
2 cell Lithium-ion batteries
Rear-Biased AWD
Widetrack bearings
Neodymium magnets
Modified Tierods
And much more
1965 Ford Mustang :Bone stock
Old 12-21-2004, 11:21 PM
Sinni Sinni is offline
Its a 240k (or 240 ohm I can't read the damn meter) resistor. Its dropping the voltage from 6v to a safe voltage for the board. The resistor can go on either the Positive or negative side, either way it's still dropping the voltage to a safe level
Old 12-21-2004, 11:36 PM
3D Racer
so...... should I try it? cause if it is just dropping the voltage then if we removed it we could use less batteries to power it thus dropping weight.
Old 12-22-2004, 12:51 AM
skyline_69's Avatar
SkyineRC Pro
would probably reduce your runtime if you reduced the number of cells...
-Paint in the works
-Mesh Front Grill
-AWD
-CL Lights
-CL Underglow
-6 CELL BABY!
Old 12-22-2004, 11:04 AM
It's a zener diode then. There's one on the board, just most people don't figure out where.
Mods:
Rear-Biased AWD
Widetrack bearings
Neodymium magnets
Modified Tierods
And much more
Old 12-22-2004, 10:21 PM
3D Racer
dude the cells are wired in a series and each has its own mah and b/c of that it would not reduce run time
Old 12-22-2004, 10:23 PM
3D Racer
what does a zener diode do?
Old 12-22-2004, 10:32 PM
Limits voltage input. Essentially it's a glorified resistor, but there are differences. It only lets a certain amount of current out, no matter how much input there is, until the voltage peak is reached, at which point most (but not necessarily all) of the voltage goes through. Works on the zener effect.
http://www.americanmicrosemi.com/tutorials/zener.htm
Mods:
Rear-Biased AWD
Widetrack bearings
Neodymium magnets
Modified Tierods
And much more
What I noticed about RS!!! XMODSaretheBEST XMODS 22 12-02-2003 09:19 PM
Something I noticed about the AWD kit. Bad Company XMODS 18 10-21-2003 08:21 PM
Noticed something viperkilla XMODS 4 10-21-2003 06:38 PM
has anyone noticed this? isk8blind Bit Char-G / MicroSizers 3 02-12-2003 07:57 PM
noticed something interesting while switching pcb boards spikeymike218 Bit Char-G / MicroSizers 7 01-22-2003 02:03 AM
