  #31
Old 12-04-2004, 02:20 AM
moebrown20's Avatar
moebrown20 moebrown20 is offline
Send a message via Yahoo to moebrown20
Originally posted by SHIFT_DRIFT
I realized that the Xmod has brakes just like the MR02.
The brake function may burn out the Turbo.
What did you use to counteract this?
(or did you just get a MR02/OL Turbo?)
There is 3 parts to the fet(that we need to know now)
1. gate or on & off switch
2. source or power
3. drain (where the power is going to)
I'm not a expert on this, but when breaking with electric motors, the energy gained form breaking goes to the fet on the board & from there back to the batteries. I think that the externals cannot do that which causes the extra energy to "burn-off" as waste. I use the gates from the board itself (like the woah nelly), the only thing I changed was the source. Instead of getting it from the board, I got it straight from the batteries. There is a thread on how to make one in the science section, but here's a pic.
Drivers Wanted.
Old 12-16-2004, 11:41 AM
n2o_matt n2o_matt is offline
Send a message via AIM to n2o_matt
Originally posted by moebrown20
I use several motors:
The stage 4 I use on the track. It tops out at 56-58km.
The Impala I use on a street track (oval or straight-away). The max on that I've seen was 65km but 60 is normal.
This new motor I'm working on Cheetah-X (named after a slot motor that was discontinued) I still get different speeds. One time I get 94 the next I get 86km. I'm looking for 82- 84km on a oval track and mid to high 90's in a drag.
since you have named these motors your self, i take it you made them from other motors. Do you mind telling us which motors you used for a base and what you did to them? Or is that "secret info"?
Old 12-16-2004, 12:50 PM
moebrown20's Avatar
I can tell you a little info. The st4: the arm is from a st2 the rest is from japan. The Impala: the amr is from mabuch motors, wire from cali and the rest is from carmoworld. The Cheetah-X: the bearings is from carmoworld, endbell can & brushes is from china and the arm is from Mabuch motors. At first the Impala motor was from a 16D slot motor cut down and modified (too much work and time) so I made a few phone calls and made friends with some vendors.
Drivers Wanted.
"Spider" Turbo for XMods and Mini-Z Released aaron XMODS Parts and Hop-Ups 0 03-23-2006 04:09 AM
Spud, LiPo Powered 25K Turbo Epoch LBRC Epoch RC1/43 3 03-29-2005 03:12 PM
turbo button mod? kitoy Auldey (All) 0 02-16-2003 04:46 AM
turbo or no turbo Spanky Bit Char-G / MicroSizers 8 12-31-2002 03:33 PM
