02-28-2004, 03:35 AM
Got an e-mail Fri stating my order has been shipped
Hopefully I will be able to get going on the adjusted version. Neuro I will post how well it works. I know that the TO-263 packages have different heat Tol than TO-220 pk.
02-29-2004, 10:00 PM
Originally posted by charliebrown
Anyways, for some quick Q's: With your FET setup, the amperage limit is pretty high, from what I hear, so I'm thinking of getting the Team Orion Elite Stock 180 motor, and taking about 20-25 winds off the armature. It will have a bit of a high current draw, but I'm guessing the FETs you're using will be able to handle that.
If you go that low, it won't have any torque at all. I've tried a 15 turn double, and even it isn't an acceptable performer, IMO. (It sure has great top end just spinning with no load on the bench, though.) It takes about 1 full second or more to spin up.
03-05-2004, 06:47 PM
Originally posted by codedat
Hopefully this should clear things up. Note connecting directly to the batteries is ok but don't forget to connect to the main PCB.
Here is a revised img
If the picture doesn't show click the link here
I belive this is what Neuro said it should be. Note directly connecting the battery is ok but remember that the main PCB needs power also.
I fix the link.
ok this is cool and all but which is ic5 and ic6. Is ic5 the left one and ic6 the right one or vise-versa
03-05-2004, 07:53 PM
I re-labled them. sorry was in a rush on a quick revision. Recheck the link again.
03-06-2004, 06:39 AM
ok ty cause i'm kinda new to electronics and stuff.
03-07-2004, 06:07 AM
No prob, glad to help. BTW check this out, it will help you on the basics of electronics.
Basic Electronics
03-15-2004, 03:08 PM
0reZepyT
neuro, i breezed through most of this thread and i dont' think this was asked. does your FET upgrade board maintain the brake function?
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
03-16-2004, 08:06 AM
Yes. All original functionality is retained.
03-18-2004, 08:09 PM
R34 Skyline is God
Code I can't see your pic.
EDIT: Nevermind, saw the link.
My Bit: Phast motor  (Orange)
Soon to come:  (Undecided) Custom Rims
03-18-2004, 08:12 PM
R34 Skyline is God
Does anyone know where I can get some colored wire from?
03-19-2004, 04:14 PM
R34 Skyline is God
Nuero, in your mod, where to we solder where it says + battery and - battery?
03-20-2004, 01:07 AM
0reZepyT
go back a few pages and there are pics to show where to solder it
03-20-2004, 07:45 AM
Proud to be Pinoy :)
Neuro! great work man!... have you tried using those big fets without the stock fets.. i mean you will remove the stock fets then repllace it with those FETS?.. just curious
hehehe
03-20-2004, 08:10 AM
R34 Skyline is God
Alright I found it, but is it on just on battery case?
By the way Nuero, what are the other FETs next to the IRF4905s in your pic?
03-20-2004, 01:23 PM
That was the way I was running it, yes. Stock FETs were removed completely.
Yes, just run another set of wires from the battery cases.
The other FETs are the IRL3705N.
