03-06-2004, 08:06 PM
New Curcuit board=fixed range?
hay. my friend has really short range, and he wanted me to ask you guys if buying a new curcuit board would fix that. answers would be appreciated. thanks
03-06-2004, 08:16 PM
the Reciever PCB Assy from CJ's faq right? thats a direct replacement for the 2 boards. you just need to solder the battery holders on and the servo on. if thats what you're talking about if not go to the XMODS section and do a search for "Extended Range?" for a fix
03-08-2004, 02:49 PM
Check under the cover of the Command Logic Port for the L1 L2 inductors. The L2 inductor is the biggest cause for short range when its burnt out.
You can get a replacement inductor at www.atomicmods.com
03-08-2004, 07:35 PM
TinyRC XModder
A little off topic...what does PCB stand for?
For Sale:
|XMod :: Black Supra|
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
-Wheel & Tire upgrade
-All Wheel Drive Kit
-Ball Bearing Upgrade
[url]
03-09-2004, 07:36 AM
TinyRC XModder
Ah, thank you.
For Sale:
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
[url]
03-09-2004, 06:22 PM
thanks for the replies. so am i supposed to buy the PCB thing or the servo assy?
03-09-2004, 08:31 PM
TinyRC XModder
You want the PCB. The servo is what turns the car.
For Sale:
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
[url]
03-12-2004, 07:22 PM
It's Really Fast!
I just put in a new recevier board into the existing board/servo/batt combo. Is that bad?
03-14-2004, 08:29 AM
i would get a servo too. then it will be easier to install that way too. then you have an extra servo to play around with. and you can use the old servo and battery holders. its ok. just be careful when you solder the wires on the battery holders that you solder it as quickly as possible. ive ruined a couple of them, the metal piece where you solder them gets too hot and the plastic melts and ruins the end of the battey holder.
03-14-2004, 10:10 AM
It's Really Fast!
Yeah, I once did that on an MS controller.
